Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2021
Old 10-17-2021, 12:33 PM
Rrsparger Rrsparger is offline
Default Midi keyboard controller
I have seen allot of posts on midi keyboard controllers that people have problems with Pro Tools. Is there a line of recommended affordable keyboard controllers that have no issue with Pro Tools?
Thanks
Old 10-17-2021, 01:21 PM
JanuS JanuS is offline
Default Re: Midi keyboard controller
Very good question!
I think none... A Eucon midi keyboard controller (with plugin mapping) would be best
Old 10-17-2021, 01:51 PM
JFreak's Avatar
JFreak JFreak is online now
I am using Novation Launchkey and have not had any issues. It would be even greater if the faders and knobs would be touch-sensitive, but it would at least double the price.
Janne
Old 10-17-2021, 02:26 PM
Ben Jenssen's Avatar
What problems exactly are you worried about? I've heard of issues with sustain pedals, but in my experience PT handles midi input devices just fine. Even my old Command|8 is solid with PT2020.
Life-long audio enthusiast and small studio owner. Retired.
Mac Mini 2018, six-core 3.2gHz i7, 32 gb RAM.
Focusrite Scarlett 6i6 2nd gen, Dynaudio BM6's, Command|8, SSL UC1.
Pro Tools 2020.11.0.157, Mac OS 10.15.7.
Old 10-17-2021, 02:28 PM
JFreak's Avatar
To be more exact, problems with midi merge, but it is most apparent when using sustain pedal. Should be fixed already, and I do not remember which versions the problem was most apparent
Janne
Old 10-17-2021, 05:16 PM
There's a bit more to learn here, so some general Midi "help":
1-Eucon has little or nothing to do with midi. Eucon is not needed for simple Midi recording from a midi keyboard, trigger pad or electronic drum kit.
2-Eucon IS needed for Transport control from a midi keyboard(if the keyboard in question has transport buttons).
3-nearly any keyboard with a Midi output can be used with Pro Tools for recording Midi to a Midi/Instrument track(for triggering a VI(Virtual Instrument) plugin(such as MiniGrand, EZDrummer, Kontact, etc)
4-Any controller will need to be configured in the Setup>Midi>Midi Studio menu(inside Pro Tools). The crucial detail there will be the Input Path(where PT will "look for" incoming Midi data). How the keyboard connects also matters(USB vs. Midi cables to the interface), but most any connection method should work.
From my own experience, I have had success with all the following:
Yamaha Motif es8
Ensoniq Mirage(don't laugh, it cost me $50)
M-Audio Trigger Finger
Roland TD-10 electronic drum kit
Akai Advance 61(without the VIP software)
Old 10-18-2021, 08:37 AM
Excellent answer albee1952,JFreak, and JanuS. I will be using it mainly for virtual instruments and laying down keyboard synth tracks
Old 10-18-2021, 11:20 AM
Eric Lambert's Avatar
I'm not aware of inherent PT/controller MIDI issues. There was a point when MIDI was placed late or early due to delay compensation problems but I believe that's been fixed for quite a while. I've used a Native Instruments S88 for years and it's been fine. The keybed is a bit noisy and the action is slightly heavier than I'd prefer, but their non-weighted controllers are solid.
Old 10-18-2021, 11:25 AM
JFreak's Avatar
Yes, working as it should. However the inherent problem of MIDI timing is that MIDI 1.0 specification from 1983 says 24 pulses per quarter note. Let's assume normal 4/4 composition with 120bpm tempo, it means two quarter notes per second, or 48 pulses per second, or one pulse per 1000 samples in 48kHz session. That is exactly how sample accurate MIDI is.
Janne
Old 10-27-2021, 09:46 AM
DonaldM's Avatar
DonaldM DonaldM is offline
I'm considering a new controller. What I'd like is one that is a full 88 keys that are either weighted or semi-weighted, with touch pads, and the ability to set up zones. And of course assignable sliders and dials. I know there's a bunch of different ones out there. I just would like some thoughts on which ones you might recommend I consider. Thanks
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones
Owner: Dragon Rock Productions LLC
original midi device associated with midi controller m keyboard could not be located willl3 Windows 1 09-23-2017 06:29 PM
Best Midi keyboard controller for PT 10? LoveSharp Pro Tools 10 3 02-06-2016 11:45 PM
Using my PC's keyboard as MIDI controller Mike1983 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-28-2009 12:58 AM
USB MIDI Keyboard Controller CharlieX 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-13-2007 06:55 AM
Midi Keyboard Controller secutanudu MIDI 0 02-16-2003 04:46 PM
