  #141
Old 10-08-2021, 02:56 PM
DetroitT's Avatar
DetroitT DetroitT is offline
Default Re: Plugin Updates - Please Post Here!
Cherry Audio Products Now Offer Full Apple Silicon M1 Native Support
  #142
Old 10-11-2021, 11:31 AM
Stephen Bond's Avatar
Stephen Bond Stephen Bond is offline
What's New In Waves V13
New: APPLE M1 COMPATIBILITY
Native M1 Compatibility with ARM Silicon computers. See full list of supported DAWs
New: WINDOWS 11 COMPATIBILITY
Compatibility for all DAWs providing Windows 11 support
New: HiDPI GRAPHICS FOR SELECT PLUGINS
Scheps Omni Channel, Abbey Road RS124 and Kaleidoscopes now with ultra-sharp HiDPI GUIs
New: ADDITIONAL IMPROVEMENTS
Ongoing improvements, bug fixes, and additional updates. See full list of updates
https://www.waves.com/downloads/release-notes
Mac mini M1 2020 16Gb Memory- 256Gb Storage, Monterey, Pro Tools 2022.9, Focusrite Scarlett 2i2
https://www.waves.com/r/djgsi6
  #143
Old 10-18-2021, 01:22 PM
K.I. K.I. is offline
Hi.
kush UpDate.
https://thehouseofkush.com/pages/downloads
  #144
Old 11-16-2021, 10:12 AM
YOU ASKED. WE LISTENED.
RESIZABLE INTERFACE
FREE Update
In order to provide a better user experience when using the Gem plug-ins on large sized displays, we made the graphic interface resizable. From the preference panel you can change the plug-in size from half of its nominal dimension (50%) to double of its size (200%).
The upgrade is FREE for any plug-in of the Gem series.
HOW TO GET THE UPGRADE
The Upgrade is Free for all Gems registered users.
Log into your Overloud user account by clicking on the button below
Go to the "download installers" page
You will see the list of the installers for the Gem plug-ins you own.
https://overloud.com/user/login
Stephen
  #145
Old 11-23-2021, 04:15 PM
Loads of updates over at Softube again. Fixes the graphics issues with a few of the plugins in the latest Pro Tools 21.10.0.67/OS 11.6.1
Weiss EQ MP, American Class A to name a couple.
Stephen
  #146
Old 11-24-2021, 09:56 AM
Orville's Avatar
Orville Orville is offline
All Eventide plug-ins are now compatible with:
macOS Monterey
AU, VST2, and VST3 natively support M1 and Intel processors
AAX natively supports Intel, and M1 under Rosetta 2
Windows 11
All Eventide plug-ins are 64-bit only. See each plug-in’s product page for further OS requirements.
https://www.eventideaudio.com/downlo...eid=3d50134998
http://www.eventideaudio.com
  #147
Old 11-30-2021, 07:00 PM
There are a ton of updates to Arturia plugins; everything from their vi's to fx. See their Arturia Service Center to see what's what. There is a problem though at least on Macs when updating the Wurli 2 vi. If you don't have 'silent install' checked in the ASC prefs you may run in to issues and the install failing.
The remedy I was given by Arturia support is to manually everything related to the existing Wurli 2 plugin, reinstall the previous revision and then use the ASC to update to the latest version. Failure to do so could result in the install failing and if you go to open the program you might get an error message saying there's a fault with some files. Arturia support says to manually uninstall the just updated revision, install the previous version, enable 'silent install' in ASC and then update to the latest version. Failure to do so could result in a visibly mangled Wurli keyboard.
Don't know if this exists for our Windoze brethren but a word of warning to be careful.
Jack
QAPLA!
  #148
Old 12-12-2021, 06:41 AM
PSP SpringBox v.1.1.1
NEW:
- Apple Silicon native support
- graphic engine with zooming
- presets explorer system
- presets from Sebastian Imbierowicz and Steve Levine
KNOWN PROBLEMS:
- routing problem on multi channel (more than 2 channels) tracks in Reaper. The right channel is muted when the VST 3 plug-in is inserted. We advice to use VST 2.4. version on such tracks.
TO BE DONE:
1. Improving stability between VST3 version of the plugin and Ableton Live host application,
2. Proper track routing in Reaper for more audio channels than two.
The update is free of charge for the current PSP SpringBox users.
1) Log-in to your PSP account and go to My plug-ins section,
2) Download the installer appropriate for your operating system. You can overwrite the newer version over the old one so after downloading simply start the installer.
3) If needed you can always return to the erlierer version.
Stephen
  #149
Old 12-12-2021, 11:30 AM
NEW:
KNOWN PROBLEMS:
TO BE DONE:
Stephen
Thanks for posting all these update notifications. I have a question though: how did you find out about this particular update from PSP? Long time customer of theirs and I don't seem to get notice of updates even though I should be on their mailing list.
Jack
QAPLA!
  #150
Old 12-12-2021, 01:37 PM
Came via email contactATTTpspaudioware.com
Stephen
HTML code is On
Where are the plugin updates? M2E AAX Plug-ins 6 01-06-2019 10:17 PM
Plugin Updates bcs723 VENUE Live Sound Systems 3 10-19-2008 07:36 PM
6.9 TDM plugin updates? jeremyroberts Pro Tools TDM Systems (Mac) 13 04-19-2005 11:11 AM
Plugin updates for 6.7 Fader Invader Pro Tools TDM Systems (Mac) 1 12-08-2004 05:50 PM
6.4 plugin updates FDurrett Pro Tools TDM Systems (Mac) 2 08-02-2004 10:33 PM
