Old 01-23-2011, 08:53 PM
ericsvizeny ericsvizeny is offline
Default Drum Programming
I have been using the tab to transient method, and it works very well for the first track, but once I start on a different track say I did the snare first, and then on the kick drum track if a note matches up when I hit the keys : and "v" to paste it deletes the other note on the snare track and I have to control z and then alt + M to merge it, because alt + M only works when I make a mistake first for some reason? Is there a way around this?
Eric Svizeny
Old 01-24-2011, 01:15 AM
danander11 danander11 is offline
Default Re: Drum Programming
Are you programming or replacing/editing? Sounds to me like you are replacing/editing.
There are a number of ways of doing it. Sound replacer, Massey's DTM, and Steven Slate trigger are common programs that folks use to make it fast and easy.
If it's just editing, I'll group the drum tracks then use either EA or manual edit to bring things into time. I'l also sometimes just cut out everything I don't want, then apply a small fade at the end of each region (start and finish) by hilighting everything then using CMND/F Once that is done I can consolidate the track and make it one long audio file.
I have to say that what you describe leaves me a bit confused.. Sorry if this wasn't the direction you were looking in..
Here I am,
after time not long...
and thankful for the break,
What I found when I got there,
was that I couldn't stay away!
Hobo Shave!
Old 01-24-2011, 08:45 AM
Thank you for trying to help, unfortunately that is not what I'm trying to do. Anyways I figured it out on my own, so it's all good!!
Eric
Old 01-24-2011, 09:43 AM
Drew Mazurek's Avatar
Option M always works here. Try trashing prefs etc.
www.drewmazurek.com
drum programming!!! stef73 Digidesign Hardware & Software 3 05-31-2006 11:10 PM
Drum Programming in PT potex Tips & Tricks 8 04-14-2006 01:45 PM
Drum Programming Help tempest18 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 12-28-2004 06:38 AM
Drum Programming FatBelly 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 04-26-2004 11:30 AM
Need Help with Drum Programming substudios MIDI 1 01-26-2003 04:35 PM
