Old 08-03-2009, 03:51 AM
JazzyJ JazzyJ is offline
Default 7200 RPM in Macbook - Superior Drummer
Hi all,
I'm about to get 'Superior Drummer' by Toontrack and will install the sound libraries on the system drive on my Macbook (5400 RPM stock drive).
I am thinking to upgrade my HD to have more space as Superior Drummer upacks to 60 GB and am wondering if there is any benefit in getting a 7200 rpm rather than a 5400?
Will a 7200 rpm internal drive make a big difference for running VI Drum modules?
or
are the sounds loaded into ram anyway and therefore the system drive speed is irrelevant?
I've heard various reports about heat and battery issues regarding 7200rpm drives in Macbooks but havn't found anything conclusive.
Any ideas or reccomendations??
Hack Pro (4.2Ghz i7 Quad/16GB)
PT11 / OSX 10.8.5
TC Electronic Konnekt 24D
Old 08-03-2009, 07:40 AM
JrummerJ JrummerJ is offline
Default Re: 7200 RPM in Macbook - Superior Drummer
Hi there,
I have Superior, and unless you are getting all the expansion packs it shouldn't be 60GB. I think the main Sup 2.0 library is about 18-20GB. Anyway, I install my samples on my external hard drive. Since you already have an external drive (presumably since you are running pro tools) I would just put the samples there and stick with your current internal drive.
J
Old 08-03-2009, 09:15 AM
Yes, thanks, I know about installing samples on external drives even though some programs don't even let you do it on OSX.....
But my question is not about locations to store samples, my question is about
5400 and 7200rpm system, internal drives on a macbook and the pros and cons of these drives regarding VI's.
Any info other than hearsay anyone?
PT11 / OSX 10.8.5
Old 08-03-2009, 02:06 PM
Tomas Chinchilla Tomas Chinchilla is offline
Absolutely 7200RPM, take the opportunity and upgrade. I personally would not do it on the original 5400RPM, I have the new macbook pro and upgraded the drive immediately, it makes quite a bit of a difference but then again there are people who don't see any.
The Black Scorpio from WD is the most stable one in my opinion, 320GB 7200RPM and it goes for about $110 to $120.
The Seagate Momentus 500GB 7200RPM is the best bang for the buck at $140 to $150 but but but, quite a few reported issues, clicking and very sensitive to movement. I personally experienced this as well and returned it, decided to go with the WD.
My 2 cents.
Old 08-03-2009, 02:39 PM
I suppose it should be fine to put a 7200 RPM drive in the Macbook. Hey Apple dose it too. As for brand, I can suggest looking at the ones from OWC at www.macsales.com. I use one of their external firewire drives and have been very happy with it. I may be wrong but I think they use Hitachi drives. The two concerns are heat and vibrations. Faster spinning drives potentially generate more heat but a properly installed drive shoule be fine in the macbook. The vibrations vary from drive to drive even at 5400RPM. I'll have to admit that the 5400 drive in my Macbook Pro is very quiet for now.
Obsidian Dragon
MacBookPro14,3 - Intel Core i7 3.1 GHz, 16 GB
MacOS 11.6 running Protools 2021.10
Old 08-03-2009, 04:54 PM
hmorovic hmorovic is offline
My 2 cents.
Thanks a lot for the first hand information!
H.
002 - MacBook Pro i7 2.0 GHz, 8 Gb RAM
OS 10.9.5, PT 10.3.10 - Mallet KAT Pro
moromusik.com
Old 08-03-2009, 04:57 PM
You are most definitely welcome.
Old 08-04-2009, 01:58 AM
Thanks for your advice everyone. I've gone for a:
Hitachi TravelStar 7K320 - Hard drive - 320 GB - internal - 2.5" - SATA-300 - 7200 rpm - buffer: 16 MB
I got it on ebay for £80 GBP new.
Now I'm hoping to use Super Duper to clone my drive to my firewire drive, then install the new 320GB 7200 drive and then boot from the firewire clone and clone that to the new drive.......
Thanks
PT11 / OSX 10.8.5
Superior Drummer 2.3.2 w/PT 10.3.8 & 11.1.2 shultzee13 Virtual Instruments 3 03-20-2014 10:28 PM
PT9 and Superior Drummer 2.0 LarsKatz Windows 7 06-13-2011 10:04 AM
EZ Drummer and Superior Drummer Problems verticleman Virtual Instruments 5 01-02-2011 12:41 PM
Superior Drummer and EZ Drummer on sale nst7 Virtual Instruments 0 09-01-2010 10:57 AM
Ez-Drummer and Superior Drummer by Toontrack Narzugon Virtual Instruments 3 12-17-2008 09:06 PM
