Old 12-17-2004, 10:19 AM
Brandonx1 Brandonx1 is offline
Default HTDM not showing CPU usage in the system usage
Hi All,
Thanks in advance for the help. First of all, I'm using a HD 1 system with very good results. I just installed PT 6.7 cs4 and all is rock solid. The only problem I'm having is when I use HTDM plugs. My system slows down so I know I'm using the cpu for the plugs. Also, the proformance meter in XP shows a increased cpu load but the cpu meter in pt does not change. It just reflects little or no cpu load, even at almost 90% cpu load in xp. Is anyone else have this issue. Thanks again.
Peace,
Brandon
Brandon Howlett
Vibe Audio Post, Inc.
Re-recording Mixer
Custom Build CPU, HDX 1, Omni, 192 I/O Digital
S6 M10 24 fader
Satellite Mac Pro, HDNative, 192 I/0
Black Magic HD Extreme
Old 12-17-2004, 10:41 AM
Rail Jon Rogut Rail Jon Rogut is offline
Default Re: HTDM not showing CPU usage in the system usage
HTDM doesn't show in the CPU Usage Window. I believe this has been reqested before.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 12-18-2004, 06:51 PM
filmixer filmixer is offline
Pro Tools doesn't report HTDM usage on a Mac either. What's up with that?
Mark Ettel C.A.S.
Old 12-19-2004, 10:45 AM
Hi Filmmixer,
I don't know why not. RTAS is shown. It doesn't make any sense. All I know is I only have an HD 1 system. I can use almost as many HTDM plugs as TDM. The other day, I crashed for the first time. It was probably because of too much cpu usage do to HTDM plug-ins.
Peace,
Brandon
Brandon Howlett
Re-recording Mixer
S6 M10 24 fader
HDX Card #2 Not showing up in System Usage Window rbillia Pro Tools HDX & HD Native Systems (Mac) 7 12-01-2013 03:38 PM
10.1.1 not showing "disk cache" under system usage [solved] Silky Pro Tools TDM Systems (Mac) 1 03-27-2012 01:21 PM
System Usage window showing incorrect info poly915 macOS 2 03-18-2011 03:18 PM
HTDM usage clarification on MIX system?runs for weeks/crash! Chris Watkins Pro Tools TDM Systems (Win) 0 12-29-2007 09:42 PM
AMIII showing in "System Usage" window SimonThornton Pro Tools TDM Systems (Mac) 2 11-19-2001 12:18 PM
