Old 02-11-2009, 12:17 PM
mrcomber24 mrcomber24 is offline
Default Setting up Machine Control option on MIX system
Hi all,
I'm piecing together an older MIX system specifically so I can remote arm my DV Cam deck and do proper laybacks to tape. I see that there is Machine Control 2.0 out there right now, but it says for HD. Does anyone use that successfully on a MIX system or do I need to get the authorization for the older original version?
Thanks in advance-
PT 6.4.1
MIX Plus, 888/24, USD
Old 02-11-2009, 06:54 PM
TVPostSound's Avatar
TVPostSound TVPostSound is offline
Default Re: Setting up Machine Control option on MIX system
I do believe that there is only one Machine control authorization.
I've had machine control since 5.11, and it's the same auth.
Old 02-11-2009, 08:22 PM
Chief Technician Chief Technician is offline
Arrow Re: Setting up Machine Control option on MIX system
Correct.
Jonathan S. Abrams, CEA, CEV, CBNT
Apple Certified - Technical Coordinator (v10.5), Support Professional (v10.6 through v10.10)
Old 02-14-2009, 09:17 AM
The 9 pin port on 888s do not work!!
You need to get a Keyspan USA-28X usb to serial adapter (MAC) or a Keyspan USA 19-HS (PC) to work properly.
Old 02-14-2009, 01:40 PM
i see--thank you very much everyone. Much appreciated!
HTML code is On
Where can I buy the machine control 2.0 option oneone Post - Surround - Video 7 07-13-2012 03:08 AM
Where can I buy the machine control 2.0 option oneone Pro Tools 10 1 07-12-2012 05:36 PM
Do I need to purchase mp3 option AGAIN after setting up a new system ? Chris7514 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-15-2010 02:16 PM
Setting up Machine Control option on MIX system mrcomber24 Pro Tools TDM Systems (Win) 0 02-10-2009 02:15 PM
Help Setting up Machine Control 2 in OS X autopilot Pro Tools TDM Systems (Mac) 3 06-02-2005 08:15 PM
