One Laptop - 2 Locations Hard Drive Solution
Hello, I am trying to find the best and proper way to do this. I have my main rig at an office. It has my interface, 5.1 setup, etc. I have been using my Mac mini i7 and it works great. However I now need to be able to work from home at times too (Smaller stereo and headphones setup).
I wanted to avoid having 2 work computers to avoid keeping up with applications and software updates for both. I was thinking about replacing my Mac mini with an M1 MacBook Pro so I can work from home too. My main concern is how to access projects from both locations. If I get another drive or RAID to have at home and use something like ChronoSync to keep it updated with my office RAID, would it work? Would I be able to close a session I worked on at the office and open it at home without a problem? OR is there a better solution for this? |
Re: One Laptop - 2 Locations Hard Drive Solution
Have you considered simply moving the Mini between home and office? Keeping sessions on the internal drive and perhaps have two externals, one at home and one at the office, for backups and other files you might need? Keeping it simple, you would also save some money, you'd need maybe a new screen and a new external drive for home. Maybe you'd need to trade the mini for one with a bigger drive, but it would shurely keep things nice and tidy.
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
I run 5.1 through my Quartet. All current work is on my 4TB internal. When I need to be on the move I just put my laptop in my bag and go. DON'T FORGET YOUR ILOK!
PT Ultimate 2023.9.0 - MacOS 13.4 - MacBook Pro (Late 2019) - 2.4 GHz 8-Core Intel Core i9 - 64 GB 2667 MHz DDR4 - Apogee Quartet - Avid Link 2022.12 |
Hi. I usually split my time working from home or freelancing in different facilities. Most of the time I simply slip a copy of the sessions I'm running on an usb drive (either Hard drive or ssd, I usually carry both) in case of additional edits, reworks and so on.
Recently I bumped into a studio I've been part of for several years and discovered that they have moved their back up strategy to the cloud. Each session is uploaded, from each studio room, to Dropbox as soon as it's closed, then it gets copied to an onsite back up server as well. They try not to clog their cloud storage too much but, working mostly on commercials, that's not much of an issue. In the end they can keep an online back up spanning at least a month, maybe two, before moving it to sole onsite. The plus of this strategy is that any single operator can access any recent session just by logging in.... even from home.
Luca de Sensi |
Bringing your hard drive and syncing it would be easy if IT allows it. I wouldn't bother with a RAID at home. But you would need to figure out how many volumes you'd need to sync. I.e. Sessions, Video, SFX Library, etc... M2's in an enclosure are getting pretty affordable.
Sessions should open and relink fine. You'd need to set a separate monitor path for your home stereo setup. Or get an identical interface if possible. Yes and don't forget the ilok with ZDT / TLC.
~Will |
Thanks all for the replies and suggestions. I will research all options and see what’s the best fit for me.
For years now, I've regularly cloned my Intel Mac Pro's boot drive to my Intel MacBook Pro. That way all prefs, plug-in versions, app versions, etc. were always identical and I would have perfect recall. But I'm worried that Apple Silicon will put a wrench in my cloning habit.
Nathaniel Reichman Producer/Re-recording Mixer - New York Nathaniel Reichman | IMDB | LinkedIn |
I used to do that to. The only hiccup was sw that used machine ID for authorisation. There were a couple that would t work that id have to re-authorise. But yes, was a great way to have an identical setup. Sent from my iPhone using Tapatalk |
That’s my setup. I use a laptop at the studio with a couple of hubs and portable ssd drives. When I need to go portable, I take the laptop and drives and a hub with me. They all fit in a backpack and I can work on the road. I just make sure to clone my system drive every day, just in case I drop my laptop.
The M1 generation won't allow the cloning anymore.
My setup is to use Resilio sync to keep my desktop, server and laptop project folders in sync. You need a server for this setup, but it's a nice way to have a backup at the same time. If you start a new project with large files, I'll bring my laptop to the studio to speed up syncing. You can use ChronoSync as well, but Resilio is easier to setup since it uses a relay server to find your server thru any network infrastructure...
Mac Studio, 32GB, PTHD2022.7, OS 12.5.1, S3, Transport, (EuCon 2022.4.0.78) LIO-8 BlackmagicDesign UltraMonitor3G Reaper 6.66, Fireface UCX MacbookPro M1Pro PTHD2021.12 MacOS12.1 BlackmagicDesign UltraMonitor3G MOTU 24Ao AppleTB3toTB2->AppleTB2->Ethernet->AVB |
Best laptop / hard drive solution | johnnyv | Pro Tools 10 | 5 | 02-26-2012 10:26 AM |
So what's exactly the best hard drive solution for recording? | Riquier | Pro Tools M-Powered (Mac) | 3 | 02-17-2011 12:56 PM |
Laptop Second Hard Drive | steverido | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 04-15-2010 12:40 PM |
Second Hard Drive (Not USB) for Laptop? | j.kernodle | Pro Tools SE and Essential (Win) | 4 | 03-30-2010 11:33 AM |
Best, fastest non-SCSI hard drive solution??? | knewbee | Tips & Tricks | 9 | 08-05-2002 09:58 AM |
