Copying plugins from stereo tracks to mono
Is there any workaround for this?
PT HD 2018.1, Mac Pro 2013, Digidesign Command 8, Focusrite Clarett 2Pre |
Re: Copying plugins from stereo tracks to mono
My solution has been to save the plug-in settings, add a plugin to the other track, then recall the settings I just created. Don’t know of a faster way.
Edward |
Doesn't shift-command-C/V work to copy and paste settings?
It works, many thanks
You cannot copy From stereo to momo with plugins... The amount of channels throws up a flag in PT and it won't allow it... Been happening for years... The Only work around is if yoh have a setting you like... Save it in the Plug in... You click on preset and then sVe settings As.... Save it... and then u can open up the Mono or stereo version of the plug and click on Factory defaults and a list will generate and u should see your Named plugin... Fastest Easiest way
Sent from my SM-N950U using Tapatalk
What I Run Daily IMAC HIGH SIERRA 10.13.6 PT 11 STUDIO A MACBOOK PRO I-9 1TB SSD 32 GB RAM, PRO TOOLS 2018, STUDIO B MAC G5 YOSEMITE, AVIDS 192'S WITH PRO TOOLS 10 STUDIO C MAC PRO 12 CORE 64 GB RAM 2TB SSD PRO TOOLS ULTIMATE STUDIO D |
If you are using multi-mono plugins, you can split you stereo channel to mono and then move the plugins from one of the newly created mono tracks to the track you wanted those settings/plugins to be on. (then you can delete those split mono tracks)
This will not work with multichannel plugins (when you do the split to mono, the multichannel plugins will disappear from those newly created mono tracks)
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
As tclash points out, shift-cmd-c / shift-cmd-v works just fine and is a big time-saver for this.
http://www.richbreen.com ---------------------------------------- Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6 |
I didn't realize you can copy Settings with Control(apple) C and V.... For past... Because that's usually a command for Regions and text etc . Ill have to try that
I Imported stereo tracks , but PT reads as 2 L&R Mono tracks ? | Seafoam_Green | Getting Started | 9 | 02-01-2014 09:29 PM |
Only mono and stereo tracks supported, some tracks have been dropped | cowfeet | macOS | 1 | 03-21-2012 07:16 PM |
A question about mono/stereo plug ins on mono tracks. | rockguitarist1255 | Pro Tools 10 | 2 | 12-24-2011 07:33 PM |
stereo tracks, mono tracks--thoughts | saeblee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-23-2005 10:45 AM |
How many Megs does a 4 minute song with maybe 3 stereo tracks/13 mono tracks take up? | Sergeman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 08-04-2002 02:31 PM |
