Old 08-22-2018, 06:34 AM
rdpar's Avatar
rdpar rdpar is offline
Default drum sample software skipping
Anyone know why when trying to edit my drums or , really just playing back , it seems like the drumsoftware , either ssd or superior , is killin my cpu. I have tried drastically reducing the number of plugins to no avail. thaks
Windows 10 Pro Tools 2019.6 Asus g752vt 17.3" laptop i7 Quad 2.6ghz 32gig ram
500gig ssd 2T ssd win. 10 Universal Audio x8P . Focusrite Clarett Octopre(NOT AN INTERFACE)
Old 08-23-2018, 03:13 AM
EdwardWilliam's Avatar
EdwardWilliam EdwardWilliam is offline
Default Re: drum sample software skipping
In addition to optimizing your OS for PT, try any of these.
Reduce the density of automation in places where it shows the most activity.
Turn off the displaying of Send Assignment Level Meters, Insert Gain Reduction Meters, and Track Gain Reduction Meters (by deselecting the display option in the Metering Preferences page).
Reduce the number of instances of Native plug-ins, or convert the Native plug-ins to DSP plug-ins (where possible).
Reduce the overall amount of Elastic Audio real~time processing by switching to rendered processing.
Increase the Cache Size setting (disk cache) in the Playback Engine dialog box.
Verify that ENABLE GPU is checked in the Operation page of the Preferences dialog box. By default, Pro Tools' video processing is enabled on the GPU (Graphics Processing Unit). This transfers video processing to the GPU, freeing up the CPU for Pro Tools audio and MIDI. However, slower GPUs may encounter poor video playback, in which case this option can be disabled, causing the video processing to be done on the CPU.
Render clip gain in tracks
Claw-click fader VUs to make them narrow.
Turn off Wi-Fi
Close all unnecessary apps (internet browsers, mail, etc.)
If using the low latency option, check the MIDI thru setting in MIDI change the default MIDI Thru set to "none" otherwise, all MID & Instrument tracks will be set to the low-latency domain.
Edward
V-Drums vs. Drum Sample Software Chase743 Virtual Instruments 18 12-20-2008 10:50 AM
best drum machine/drum software robotman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 24 07-09-2005 12:09 PM
Drum Machine or Drum Software pacodub 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-23-2005 11:29 AM
Drum sample Erikmusicman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-12-2003 10:08 PM
Drum Tracks ... Software or Drum Module? BRB 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 01-05-2003 02:03 AM
