PT Video out HDMI on Mac Mini / iMac
With a new Mac Mini / iMac,
Can you use the HDMI port to output video from the Pro Tools timeline? Can you daisy chain two Apple Thunderbolt displays from one Thunderbolt port? Can you run a converted DVI monitor output for the main PT display daisy chained off a thunderbolt chassis for an HDX / native card? Just to clarify Mac Mini - (Thunderbolt) - Thunderbolt Chassis - (Thunderbolt) - (DVI Converter) - Main Monitor. Many Thanks Ben |
Re: PT Video out HDMI on Mac Mini / iMac
Hello,
Yes but it's a regular computer monitor output. No. Yes. Hugh |
Thanks,
Does Pro Tools recognize the HDMI out as a valid audio out? Randall |
This totally works. I just finished a show working on a mac mini attached via HDMI to a home theater set up.
Sound Editor Dual 2.0 G5 RevB 2 gigs of ram DVToolkit 2 PT 7.3 OS 10.4.8 |
Does it look as smooth / good as a blackmagic card? I've used monitor outputs before but they don't have (I think it's called ) deinterlacing. That's why video out a monitor output won't look good, plus it looks like it skips frames sometimes. Smoothness is a big deal to me, has to look like it does when its broadcast.
Ditto. Going into an (admittedly expensive) Anthem processor for high quality D/A as well as their terrific room EQ and bass management in my projected theater was actually a bonus over the passive chain I usually use. I listened to some print masters of films I had dubbed in full-sized stages and they were right on. I may be permanently done with AVID hardware on the output stage for editing and mixing purposes. Your mileage may vary.
Do you mean you sent a mix from PT to "aggregate output" and that went to the Mac minis built in HDMI output then to the anthem signal processor? For audio only? You don't get more than 2 channels do you? This setup sounds interesting I bet it sounded really nice. Thanks kindly |
I bet that sounds so good the converters would be excellent Kd |
Same cable - projector treated as second display. I, too, am blown away. The converters sound quite good. For my needs I'll take the combined solution I'm getting over an Omni any day (I really can't say enough about ARC eq - especially since I find the Audyssey EQ I've tried unlistenable). Other processor/preamps that take LPCM over HDMI would obviously also work but I would be a bit careful since they're often feature-rich for home theater but the audio chain is not professional quality. I don't currently feel that this configuration is at all a compromise and I'm a big passive-chain/minimum-processing guy.
Calculating Video offset hdmi external monitor | justanotherpostguy | Post - Surround - Video | 48 | 12-28-2012 12:31 PM |
New Mac Mini with HDMI port out today | nst7 | Post - Surround - Video | 20 | 08-18-2011 08:53 AM |
delay and video offset from minidpslay port to hdmi? | justanotherpostguy | Post - Surround - Video | 6 | 03-08-2011 12:15 PM |
HDMI Video Output options ?? | TommyT | Pro Tools TDM Systems (Mac) | 6 | 02-14-2010 02:12 PM |
HDMI video splitter/amplifier | garnoil | Post - Surround - Video | 4 | 09-13-2009 07:47 AM |
