Help with strike
I've installed Strike 1.5.x on a Mac running OS 10.8.2 with Pro Tools 10.3.2. It was a download from AVID. The Plugin launches on an instrument track (routed via buss out 1-2 to an audio track with input set to Buss 1-2) but I have nothing except empty folders in the browser window. I can select patches from the presets pull down menu and it indicates that the preset has loaded. Yet, no sounds. I've run the updated "set content" app and have ensured that the content data files are located.
Shouldn't there be preloaded kits, styles, etc in the folders in the browser window? If they aren't showing up there, any idea how I might resolve this issue? Thanks gang!! |
Re: Help with strike
I'm running the same version of Strike, Mac OS, and PT. There should be lots of kits available in the browser window. If you see that the patches have loaded, then the kits should be there. When you select a new kit do you see it loading? It only takes about 5 or 6 seconds so you have to watch quickly. Not sure what your level of PT expertise is but you don't have to route Strike to a buss and then the buss to an audio track. The instrument track will route to your main output of PT.
Problem with Strike 1.5-Pro tools 10 wants to move Strike.dpm to unused folder. | We live forever | Virtual Instruments | 55 | 09-17-2012 06:02 PM |
Strike - Songs recorded with Strike - Post Yours | JCWarrior | Virtual Instruments | 12 | 05-16-2011 12:36 PM |
Installed Strike, activated license with iLok> no Strike. | seeeker | Virtual Instruments | 3 | 10-17-2010 04:21 PM |
Upgraded to PTIEP from Strike, do I need to uninstall Strike 1.0.2 first? | cmedina | Virtual Instruments | 0 | 04-20-2010 09:37 AM |
DAE error #7400 PC (STRIKE only)????? STRIKE WONT LOAD!! | TREBLEBLEED | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-21-2008 08:19 PM |
