Why Do I Hear The Input of 11R in Logic?
Even with nothing in record, and no tracks with inputs assigned, I can still hear 11R as if it's in INPUT MONITOR mode...what is the deal with that?
Thanks T |
Re: Why Do I Hear The Input of 11R in Logic?
That's because Logic isn't really supported. It works just fine, but you'll always hear the input of the 11R. I have/had the same 'problem'. If you start Pro Tools the input of the 11R is disabled/muted.
A solution that I found, and the only one I have found so far, is to open up protools (so that you don't hear the input anymore) and then start Logic and everything just works fine! It would be great if avid would find a permanent solution to this, especially since the allow all interfaces with Pro Tools 9. It would be cool if the Avid interfaces also work with all functions in other programs :) |
It just becomes an annoyance to always have to go to Pro Tools and/or the Eleven Rack itself to make adjustments.
Mac Pro 8-core 3ghz, OS 10.6.7, 16GB ram PT 8, Digi002, Cubase 6, Logic 9, MOTU 2408mk3, Eleven Rack |
Tom |
Don't just start Pro Tools. The Eleven Rack interface has to be loaded. You'll notice when this happens when you play your guitar, but don't hear any sound until you record enable a guitar track in Pro Tools (or Logic for that matter) :)
input volume at zero but still hear input | tonyK | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 11-07-2009 12:22 PM |
Hear the input on headphones? | possumday | Pro Tools M-Powered (Win) | 1 | 10-05-2007 08:04 PM |
can't hear input during playback | rezin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-16-2007 08:16 PM |
HELP!!! CANT HEAR INPUT SOUND | sbio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-09-2007 01:28 AM |
HOW can i hear logic thru the 002 ?? help! | cane | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-12-2002 11:29 AM |
