Old 01-05-2009, 10:04 PM
tickles tickles is offline
Default Pro Tools Doesn't Launch After security update
I've seen similar posts on this forum, but it is unclear if:
a. a resolution has been found; if so, what is it?
b. if a resolution is being worked on.
I have a Macbook Pro Intel w/ OS 10.4.11 and Pro Tools LE 7.1.1. I took the Security Update "Security Update 2008-008 (Intel)" (1.0)
From there on out I got the bouncy Pro Tools icon and silence. I dug around in the log files and found the logs indicating the crash. I registered for this forum and ran the prebind script. I used the disk utility to Repair Permissions on my Internal Hard drive. Note that I have Pro Tools installed there, but have all of my sessions on an external drive connected via FireWire. I didn't run Repair Perms on the external drive as it wasn't an option and wouldn't have anyway - a bit paranoid.
Needless to say, my life depends on ProTools. I have a songwriting gig with a deadline and need to get this fixed. I also need to provide my client with a reasonable timeline for a delay on my deliverables until this is fixed. Do you folks have an ETA for a fix?
Thanks and Cheers!
Old 01-06-2009, 01:36 PM
DigiTechSupt's Avatar
Default Re: Pro Tools Doesn't Launch After security update
ETA for a fix is probably a week at the earliest.
If you absolutely need to get going, best to do an archive and reinstall of the OS and do NOT install the security update, then reinstall Pro Tools.
Avid Audio Tech Support
Support FAQ
Old 01-06-2009, 03:24 PM
Okay. Thank you for the ETA. Please advise when the patch is released. (If there is a way to subscribe to a patch list please let me know how, and I will gladly do so.)
Thanks Again.
Old 01-21-2009, 08:36 PM
Hi Digi Support,
I see a patch for this was released for 7.3.1. Does Digidesign plan to implement a fix for 7.1.1?
Thanks so much.
MAC OS 10.4.11- Protools 7.3.1 won't launch after Security Update HolyTalentMusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 38 03-31-2009 07:59 PM
Pro Tools 7.3.1cs8 - Fix for OS X 10.4.11 Security Update Avid Pro Tools M-Powered (Mac) 1 02-18-2009 12:49 AM
Pro Tools 7.3.1cs8 - Fix for OS X 10.4.11 Security Update Avid Pro Tools TDM Systems (Mac) 0 01-16-2009 11:32 PM
Pro Tools 7.3.1cs8 - Fix for OS X 10.4.11 Security Update Avid Technical Alerts 0 01-16-2009 11:29 PM
LE won't launch since latest OS X Security update glavender 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-22-2008 05:22 AM
