Digitest failure
I've got my hands on a mix2 set of cards and a d24 core with 3 farms. Recieved a 733Mhz G4 today, plugged in the 2 cards for the mix, ran digitest everything was ok, ran PT no problem. Before I tested the D24 cards I tried putting the Mix farm first slot after display cards, then the D24 core, then the D24 farms. On the TDM transmission test I got failures related to 'No TDM clock detected'. I the tried the straight D24 set of cards, same problem, though I did bring up PT and play audio with no apparent trouble. Then I put the mix set of cards in and have the same problem with TDM clock. Should I be worried about this failure, how is it affecting the sessions and pertaining audio files?
Re: Digitest failure
I forgot to mention, it's 5.1.1 on OS9.2.2, no expansion chassis and I have tried other cables to connect the cards
Thanks |
Has anyone ever noticed this 'No TDM clock' before? How worried should I be about it?
Bump
Digitest failure | Toto2004 | Pro Tools 10 | 3 | 05-03-2014 11:36 AM |
DigiTest failure? | UCB_Theater | Digidesign Hardware & Software | 2 | 12-12-2006 06:13 PM |
digitest failure | jackruston | Pro Tools TDM Systems (Mac) | 23 | 08-10-2002 12:59 AM |
Digitest failure | gitarrcarl | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-18-2001 05:51 AM |
Digitest failure | Redsandblu | Pro Tools TDM Systems (Mac) | 0 | 12-11-2000 04:29 AM |
