Protools6.4 automation not responding correctly
Protools6.4 automation not responding correctly.
I'm using it on a small session (24tracks) with some plugins, I have automation on a send (mute) muting the send every other quarter note for an 8th note duration, the result is inconsistent, meaning that sometimes it will not mute and also it will mute for longer than an 8th note. As a test, I created an audi track with a 1k tone recorded, created a send to buss 1 with the same automation previously mentioned, created a second audio track with buss 1 as the input, recorded it for 30 bars , the result is the same, the tone recorded on the second track is not at the same place as the "unmuted" parts were, the problem is random. Please Digi can you comment on that ! PT6.4 HD3 G5 dual 2gig / 4gigRAM 192 Thanks in advance
Life is good !! Marcello Azevedo |
Re: Protools6.4 automation not responding correctl
Do you have Mute Frees Assigned Voice turned on? It can cause this to happen. You can find it under the Operation menu. I this is not the case please let me know. Thanks, Digidesign Tech Support |
The Mute Free Assigned Voice is turned off.
Thanks for the response
Pan Automation not playing correctly in PT10 | WernerF | macOS | 31 | 03-27-2015 10:55 PM |
PT 11 Automation not engaging correctly | garnoil | Post - Surround - Video | 10 | 03-04-2014 11:20 AM |
Selector tool not responding correctly | play4theworld | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 09-22-2010 06:55 PM |
Automation - Not responding | mlsound | Tips & Tricks | 7 | 10-22-2005 11:16 AM |
6.1 Mutes/automation not responding sometimes... | Roy Howell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 17 | 12-19-2003 06:13 AM |
