  #171
Old 10-12-2011, 04:53 PM
CoiLive CoiLive is offline
Default Re: Best foot controller for use with Eleven Rack?
Well, I do see a need for more fx. Even only for some pitch shifting (mostly and octave down for me), an extra distortion (from crunch to more extreme overdrives) and an extra delay for some more spacey effects.
I'll take the mere 2ms for granted.
Especially when you can use the HD500 as a backup and even as a handy 2 go guy for when I don't want to take my big 11R Rack and unplug all the cables etc. :)
I think I'll be selling my FC300 and buy a nice HD500 for this one :)
  #172
Old 10-12-2011, 05:32 PM
Deny Deny is offline
Cool, in that case you might want to take a look at the tutorial I've written at TGP for getting the two units working together:
http://www.thegearpage.net/board/sho...d.php?t=877456
Deny
My SoundClick Page
  #173
Old 12-04-2011, 12:30 PM
electricfiddle electricfiddle is offline
So is the "Ground Control Pro" the unit you "can't go wrong" with?
Violin, Viola, Mandolin, Guitar, Bass, Cittern, Bouzouki, & Keys. Diamond, Strymon, Neunaber Technology, Lovepedal, Paul C., Boomerang, Sonic Research, Boss, DTS, Radial, EHX, TC Electronic, Xotic, Tech 21, and Damage Control Pedals.
Eleven Rack
  #174
Old 12-04-2011, 12:36 PM
Benoni's Avatar
Benoni Benoni is offline
It matters what you want to do. And what form factor do you like.
Another option is to get an FCB1010 and the EurekaProm from Eureka Sound.
www.eurekasound.com
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
  #175
Old 12-04-2011, 01:42 PM
richpjr richpjr is offline
I am using the GCP and it works very well the the 11R with little messing around.
  #176
Old 01-02-2012, 09:24 AM
Kruegmeister Kruegmeister is offline
Lightbulb Re: Best foot controller for use with Eleven Rack?
I am using the Behringer FCB1010 Stock (No Special PROM)
It works great but you have to do your programming on the Foot Controller.
I am in Bank Mode so I can have a Bank with 10 Presets, this is the way I prefer as opposed to Stomp Box Mode (I think it can do that too)
For Midi Patch A1 is 1, B1 is 5, etc... I have them listed in this Spreadsheet I made.
http://www.intecautomated.com/blindi...yBankv2_01.xls
The Biggest Two Procedures:
Preset Mapping - Which Program comes up when you press button.
You have to Select the Bank with the Bank Up Down and then Select a Preset 1-10 (It should be lit up)
1) Press and Hold Down Button (2.5 sec)
2) Press Up to Confirm
3) Press 1 Button (Always 1, you selected the preset prior to Holding down)
4) Press Up to Confirm
5) Enter Patch to Recall (M4 would be 52, press 5 then 2)
6) Press Up to Confirm
7) Press and Hold Down Button to Save (2.5 sec)
Footpedal Mapping - Continuous Control of Parameters
3) Press 8 or 9 Button (8 is Left Pedal)
5) Enter CC Number (11 is MultiFX, 4 Wah, Volume 7)
7) Enter Minimum (0-127, 0 is OFF and 127 Full Volume)
8) Enter Maximum (0-127, 0 is OFF and 127 Full Volume)
9) Press and Hold Down Button to Save (2.5 sec)
You can also send A Toggle upon loading each preset.
For instance I setup a Tuner Patch on Bank 5 preset 5
3) Press 6 Button
5) Enter CC to send (Tuner is 69, press 6 then 9) (0 to turn off)
7) Enter Minimum (0)
8) Enter Maximum (127)
  #177
Old 01-02-2012, 11:19 AM
Righty27 Righty27 is offline
http://www.rocktron.com/products/con...rs/midiraider/
  #178
Old 01-02-2012, 12:48 PM
SloeGin SloeGin is offline
Originally Posted by Righty27 View Post
seems interesting. How much is it?
can't seem to find a price anywhere online ...
  #179
Old 01-02-2012, 02:43 PM
I understand it's just been announced.
  #180
Old 01-05-2012, 08:37 AM
UG99999 UG99999 is offline
The standard prom for Behreinger FCB 1010 does nearly anything that the other proms do.
See here for a sysex file and explanation:
http://duc.avid.com/showthread.php?t...hringer&page=2
[SOLVED] FCB1010 Foot Controller (stock PROM) with Eleven Rack The Sentinel Eleven Rack 12 10-10-2018 12:18 PM
FS: Eleven Rack with FCB1010 Foot Controller J-mo Buy & Sell 0 07-08-2012 11:27 AM
Advice for Foot Controller and Rack/Case for Eleven Rack? udamann88 Eleven Rack 19 03-08-2011 06:24 PM
tonelab LE as foot controller for eleven rack? remis Eleven Rack 2 01-20-2011 02:03 PM
THE FOOT CONTROLLER for the Eleven Rack and any other rack modeler for that matter.. vkaxeman Eleven Rack 3 01-19-2011 04:13 AM
