OS 10.2.8 approved ???
Audio peace |
Re: OS 10.2.8 approved ???
As far as I know, 10.2.6 is the most recent version of OSX, and yes, it is approved. Are you privy to some secret info regarding OS 10.2.8?
Apple released the 10.2.8 update today:
Mac OS X: About the Mac OS X 10.2.8 Update I would wait until Digidesign approves the update before installing on your Pro Tools system. Some updates work without any problems, other can break PT. Before installing any OS update, backup your system. Also, run Disk Utility->Repair Permissions after installing. Mark |
WARNING: Do not update to 10.2.8- there is a problem on some Macs that will totally disable ethernet connection. To safeguard this make a backup copy of the 10.2.6 AppleGMACEthernet.kext which resides in: System>Library>Extensions folder. You will have to log in as "root" to do this. After you have updated to 10.2.8 and you lose ethernet you can safely replace with the back-up extension and restart. Also trash the Extensions.kextcache and Extensions.mkext files.
My System is: Mac Pro 3.2GHz 6 Core 32GB RAM 1- HDX 1 - Apogee Symphony Mk2 8x8 1 - HD 16x16 Interface MOTU MTP/AV ------------------------------ Second System Mac Pro 2013 3.5GHz 6-core Xeon E5-1650v2 32GB RAM 1 - HDX 1 - Avid Thunderbolt 3 Expansion Chassis 1 - HD 8X8 Interface MARVINBASS Digital Audio, LLC Ex PT Beta Tester Woodland Hills, CA. |
No problems here that I have noticed.
Dual867 6.1 MIX24 ymmv -------------------------------- No worries if you have a good backup. Carbon Copy Cloner http://www.bombich.com |
There's a report of the possible problems you may encounter at Macintouch
But I have been reading of lots of people with problems, so it might be good to wait on this one. |
FYI, apple just pulled it from their servers.
Although I'm trying it out now and it seems OK... |
Is OS 10.8.2 approved for PT 10.3.2? | nukepicnic | macOS | 8 | 12-04-2012 02:17 PM |
OSX 10.6.5 now approved | Obsidian Dragon | Pro Tools 9 | 0 | 12-30-2010 09:07 AM |
FYI: Mac OSX 10.4.2 Now Approved! | MARVINBASS | Pro Tools TDM Systems (Mac) | 4 | 07-23-2005 12:28 AM |
OS 10.2.8 approved or what? | digigirly | Pro Tools TDM Systems (Mac) | 4 | 10-17-2003 10:05 PM |
10.2.5 approved | Dutchmuzik | Pro Tools TDM Systems (Mac) | 0 | 05-15-2003 01:55 PM |
