Problem protools & soundcard
I have a PC under Windows 10, a UR22C steinberg soundcard and when I open protools, no other application can play any sound. Would you have a idea to solve this problem ? Thank you |
Re: Problem protools & soundcard
Use the builtin soundcard to play Windows sounds. ProTools wants to be the sole user of a soundcard in Windows.
Thanks for your answer
1-use a monitor/source selector(like Audient Nero or Presonus Monitor Station, for example). Not the cheap solution, but probably the best solution. 2-grab a small mixer(think Behringer, Alto, Alesis, etc) that has 2 stereo line inputs. Feed 1 set from the interface outputs. Feed the other set from the on-board sound card(mini-TRS to dual mono quarter inch plugs). Connect the mixer outputs to your speakers and balance the 2 sources with the mixer volume knobs. This solution might cost less than $40-50.
Merci
Problem: ZOOM H6 as soundcard to ProTools 10 | johanmusik | Pro Tools 10 | 3 | 06-12-2014 10:07 PM |
ProTools 9 with NO soundcard... | fabs6 | macOS | 3 | 06-01-2011 02:11 PM |
Problem with Vista's soundcard | stump | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 11-17-2009 08:14 AM |
do i need a soundcard to run protools | sethbrand | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-12-2005 11:51 AM |
Best Soundcard(MAC) for Cubase& ProTools | Moses Saxon | Pro Tools TDM Systems (Mac) | 0 | 07-05-2000 01:48 PM |
