Old 02-17-2025, 10:38 AM
daeron80 daeron80 is offline
Default How can I change Aux I/O device names?
When the Aux I/O feature was first added, my most common use was with a VOIP provider called Ring Central. So, I created a new stereo in/out pair and named them RingC. Today, I only use Teams for this, so I've tried to rename them Teams. I can rename the busses in I/O. But I can't figure out how to rename the devices themselves. They're still named RingC in Mac's Audio MIDI Setup. How can I rename them? Here's a screenshot of my Aux I/O page.
David J. Finnamore
PT 2024.10.1 Ultimate | Clarett+ 8Pre | macOS 14.6.1 on a MacBook Pro M1 Max
PT 2024.10.1 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Old 02-17-2025, 11:27 AM
Eric Lambert's Avatar
Eric Lambert Eric Lambert is online now
Default Re: How can I change Aux I/O device names?
There's a text file which contains the names of those devices -- it can be edited. I don't remember its location but someone here will post it. This may be helpful: https://producenewmedia.com/pro-tool...-customization
Old 02-17-2025, 12:09 PM
Thank you! That worked. It's not easy. You have to add yourself to the folder permissions, edit the document shown on the above webpage, and restart. But it worked.
David J. Finnamore
Old 02-17-2025, 01:21 PM
Since I was able to create the busses originally with Aux I/O in Pro Tools, it's a little weird that I can't rename them in the same interface. Maybe they can fix that in a future update. Editing permissions in your Mac Library folder is akin to editing a Windows registry. Sometimes necessary but always risky.
David J. Finnamore
Old 02-17-2025, 04:37 PM
In this case there's almost no risk of screwing up OS-level activities just by editing this doc, though it's not a bad idea to save a backup of the original file just in case.
I'm honestly surprised you're unable to edit the names directly within PT. I've not tried (because I changed names in the document when that functionality was first released and haven't changed it since) but it would make a load of sense to have that editable.
how to change the names of your bus tracks remusjacobs macOS 2 07-06-2012 02:46 AM
PT losing device names when going to 10.3 panther mike connelly MIDI 0 03-24-2004 04:04 PM
OSX Midi Device Patch Names (how)? Earthling 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-06-2003 02:10 PM
Managing Midi Device Patch Names in XP Patrick J. Terry 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-12-2003 06:15 AM
Device Mode changes from Patch Names Window in OMS Macavity93 Pro Tools TDM Systems (Mac) 1 01-05-2000 08:20 PM
