Old 05-20-2010, 08:16 AM
iamtenninjas iamtenninjas is offline
Default Bizarre sync problem on imported QT
I have a .mov file that plays in sync in Quicktime, but goes out by 4 frames when I import it. It starts in sync, and goes out somewhere between 6s and 16s (no audio in between so I can't determine exactly when). It remains out by the same amount throughout, so it can't be a pull-down issue (I tried adjusting these settings anyway, and it didn't help). I checked and my video sync offset is the same as it always is (I also tried setting this to 0, which didn't help). It's as if PT is adding 4 frames of silence to the audio on import. I've tried reimporting, and get the same issue each time.
System:
PT LE 8.0.3cs1, MBox 2
OS X 10.6.3
Mac Pro 2x 2.66 GHz Dual-Core Intel Xeon, 3 GB RAM
Session is on an internal SATA drive
Imported WAV tracks out of sync Aster Windows 6 03-15-2014 02:12 PM
Bounce to Disk, import to FCP - bizarre sync issue smack5099 Post - Surround - Video 10 03-19-2008 06:42 AM
7.3.1 CS3. Imported video trk is 2:30 out of sync tsr2 Pro Tools TDM Systems (Mac) 0 07-05-2007 04:28 AM
How sync up imported drum tracks barketta 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-21-2005 08:25 AM
How to Sync imported drum tracks barketta Tips & Tricks 0 02-19-2005 11:05 AM
