Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 07-03-2006, 07:53 AM
ofsaints ofsaints is offline
Default Monitor Controllers
Hi All,
What are you using for a monitor controller ( i.e Presonus Central Station, Coleman Audio, SPL MTC, etc). I didn't find much talk in my search of the DUC.
There seem to bee some good "expensive" options out there as always (i.e. Cranesong, Dangerous Music, etc). Trying not to break the bank on this one.
Any suggestions?
Thanks,
Charlie
Old 07-07-2006, 05:29 AM
macr0w macr0w is offline
Default Re: Monitor Controllers
The only monitor controller I have is my C/8 and you know how awesome that is. I have been looking at the SPL or Coleman units for a while. Once I get to the point of really needing one I'll report back.
Intel I7 920
Asus P6T
Digi 002R.
Command/8
PTLE 7.1 MPT
www.clearspotrecording.com
Old 07-07-2006, 12:33 PM
Styles Bitchly Styles Bitchly is offline
I'm using the Presonus Central Station for my HD rig. I have a control 24, but the monitor section was a little lacking for what I needed. The Central Station has worked wonderfully, and given me a lot of options for signal routing. Also, there is no coloration of the sound because the relays within the unit are all passive. There's no circuitry (ICs, Op Amps, transistors, etc. . .) to change what's coming in and out. Hope this helps.
Due to budget cuts the light at the end of the tunnel will be turned off until further notice.
http://www.gidakdigital.com
Old 07-07-2006, 05:08 PM
Thanks for both your replies.
The decision is as good as made.
Styles, thanks for the additional info. I can totally relate to your control 24 monitor section woes.
I'm looking to get a small format, highend mixer in about 6 months to a year. The CS should hold me over until then. Lots of cool choices popping up on that horizon.
Cheers,
Charlie
P.S. great quote
MBox 2 Pro Monitor knob has stopped changing monitor levels Rumandolin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-21-2013 09:13 AM
External Monitor Controllers dickcat Post - Surround - Video 4 07-15-2005 03:57 AM
Magtrax/Audient monitor controllers speedyk5 ProControl, Control|24, Command|8 0 02-17-2002 10:29 AM
Magtrax/Audient monitor controllers speedyk5 Pro Tools TDM Systems (Mac) 0 02-17-2002 10:28 AM
Magtrax/Audient monitor controllers help speedyk5 Tips & Tricks 0 02-17-2002 08:16 AM
