Not to whip a dead horse but,
Some of you may know that I have relentlessly persued a reason why my M-audio Project Mix I/O control surface will not fully function with Pro tools 9, (Or
with any version I've tried with Pt's 9.) I hate mixing with a mouse. I started computer recording several years ago but I had a major setback, (A stroke and bypass surgery). While recovering I started recording with Alesis ADAT which let me use my Mackie 24/8 board to track and mix. Just like the old tape days. Prior to the stroke I had purchased the Project Mix. When I decided to return to Pro tools I Purchased the upgrade to 9 because I was told that Project Mix I/O was compatible with 9. After several on the phone sessions with Sweetwater they were unsuccessful in fixing the problem. Now they tell me that the problem isn't Pro tools/Project Mix compatibility but that It's because I can't do a firmware update on Windows 7 ! Can anyone confirm this and, if it's so, I'll drop the whole thing for good. Thanks. |
Re: Not to whip a dead horse but,
Thanks Shan but, please clarify as I am not all that computersharp. I understand updating drivers but firmware, I haven't a clue. Thanks
I think he meant what is the procedure to update the firmware... I havent been following your earlier posts but can send you this link that has step by step directions to install the drivers and then to install/update the firmware. I hope this helps.. and if you have tried all this I am sorry as I said I havent been following, but it does tell you how to update the firmware...
http://www.m-audio.com/?do=support.f...9bcb662a9398fd |
Many thanks Craig F and jasonhurley for your assistance. First, The software was updated but I don't think the firmware has been. Anyway this looks like it could be the solution to the problem. I am currently on Windows 7. will this procedure work for me? Will I need to remove my current I/O,(Audiophile 2496) pc hardware first and then Install the hardware for the Project Mix I/O? I currently have Internet access but I don't go on line unless it's for Avid info as I fear corruption of my system. I was told, and I don't recall the source, that I could not run a firmware update for the Project Mix on Windows 7,(?).
I know I am requesting a lot of info and I don't want to look a gift horse in the mouth but I will be most appreciative if this works. Thanks again. |
http://www.m-audio.com/index.php?do=...57b2af8e313305 |
Thanks necjamc. I'm venturing into unknown territory with this endeavor. One more, and I hope the last question. My pc is Windows 7, 32 bit. My wife's is an older operating system. Windows Vista, (I think). Anyway, I know it is one of the 2 listed on the Avid link you supplied and I'll verify before proceeding. Here's the question. Can I download the firmware updater to my wifes computer to a CD, then put the CD in my pc and install it ??
I've used this process for driver downloads and it worked. I don't want to do anything that might screw up the war departments' pc. Again, thanks for your help |
Thats a good question... I'm not sure... I usually always do this while being "online" on the actual computer I am updating the firmware with....
I'm gonna say no. I'm assuming the problem with windows 7 is related to the actual update to the firmware and no matter where the file came from you still might encounter that problem. That's not for sure, but I oils t risk bricking it. It's a big risk to take. If possible, and the OS on your wife's computer is the right one, I would do the updates there. And just uninstall drivers etc after. Just to be safe.
A downloaded file does not change its composition no matter what computer or media it's copied to, it just won't run if opened on a computer that is running an OS that the file is not compatible with.
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
Beatin' the dead horse.. | Numi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 24 | 11-11-2008 04:39 AM |
Probably a dead horse, but PT w/Leopard 10.5 any time soon? | Joel Belmont | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-05-2008 06:07 PM |
Not to beat the dead horse, but... | Eric L | Post - Surround - Video | 3 | 10-25-2005 02:36 PM |
Don't want to beat a dead horse but... | Gibsonexpl | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 08-19-2005 01:49 PM |
Not to beat a dead horse but.... | zdoob | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 10-30-1999 11:52 AM |
