Automating volume
Hello.
Can someone explain to me how can I reduce the overall volume of a group, let's say all hihats and cymbals that already have an automation on volume fader? Do I have to create another aux (I already have tooo many of them) and route those channels to that aux and lower the fader or is there another way around? |
Re: Automating volume
Sorry I'm a PC user but it should work in the same way...
Create a Group with the tracks you want to move up or down the overall level(if not already done). In the edit windows with Volume view on the tracks, select the trimmer tool, and go to the very end of your session (at least after the last breakpoint). Hold click on one of the track volume line (all the lines turn dotted), then move it up and down as desired. All your automations lines should move without changing the relative automations already written before. |
This is along the line of what I need, but I want to be able to control the volume of all the tracks in a group while a few of those tracks have automation. The above method will do one track of a group and retain the automation but I want to retain automation and control all tracks in the group in one motion.
Mac Pro - 8 core 2.8 GHz - 6GB RAM - 10.5.8 Pro Tools LE 8.0 - MPT2 - 003R |
If you enable the group you make of the 3 tracks, show volume(in the edit window) and zoom out)so the whole song fits on the screen) you can grab any volume line of the grouped tracks(after the end of the song) and drag it up/down as you need. All 3 tracks will change and all the automation moves will be retained. You could also insert a trim plugin on any of the tracsk, adjust the volume and then copy/drag the same trim plugin and drop it on the other tracks.
make sure they are grouped in the edit window.
(Link Edit And Mix Groups)
William Wittman Producer/Engineer (Cyndi Lauper, Joan Osborne, The Fixx, The Outfield, Hooters...Kinky Boots!) |
Oooo, that could be it since I think I only checked mix and not edit.
+1. Simple and effective.
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
I want to be able to adjust the volume with automation on all tracks in a group while listening, so one track at a time or a copy and paste won't do.
If you want to hear the change in real time, you probably need to route them to an aux track. Otherwise, change the automation levels of the group, listen back, ||: fine tune, listen back :|| until happy.
David J. Finnamore PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB |
Automating EQ | jboogz | Pro Tools M-Powered (Mac) | 3 | 12-02-2009 03:06 AM |
Automating Volume Clicks | peter99 | Pro Tools TDM Systems (Mac) | 8 | 06-22-2009 08:12 AM |
Automating Volume Fade at the end of a song | Room335 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 11-19-2007 07:13 AM |
Automating Track Volume with Midi Controller | Dr. H | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-07-2006 03:44 AM |
Automating volume in real-time | BlackOctopus | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-25-2003 01:03 AM |
