Boot Camp and RTAS Intel plugin versions
As I'm considering buying a new 2.0Ghz iMac. I have a few plugins that I'm positive will only work in the XP environment. In effect, I have two questions.
1. Will the previous versions of PT (ie. 6.4) work with Boot Camp? Since after all they are compatible with XP Pro and an Intel processor. 2. Will Xp versions of plugs like Waves IR Bundle and Antares Auto Tune, work on Boot Camp? I am unclear as to how powerful Boot Camp is, or rather how compatible it is with previous PT and Plugin versions. Any advice would be appreciated. |
Re: Boot Camp and RTAS Intel plugin versions
Boot Camp is simply a "boot loader" that lets you install and run XP on the Mac as if it were a normal PC. Everything will be pretty much exactly the same as if you were running XP on a standard PC. All your windows/intel plugins should work just as if you were running it on a normal PC.
The only caveat will be that since an Intel iMac is a dual-core machine, you might have to disable one of the cores while you are running Pro Tools for PT to run stable. Details on how to do this are from my previous post here . You might or might not have to do this, I haven't tried Pro Tools 6.x with an Intel dual core CPU yet, only AMD. P.S. -- I have a 2 GHz Intel iMac and it is a wonderful machine! Very recommended. |
Brilliant.
Absolutely spot on guidance. Thanks so much. |
Boot Camp - Dual Boot, Dual Versions of PT LE? | bilco | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 03-17-2009 04:15 AM |
PT M-Powered 7.1 XP Boot Camp, 20" Intel iMac Prob | Gilbert Espiridion | Pro Tools M-Powered (Win) | 7 | 10-05-2006 06:45 PM |
Apple Boot Camp to solve intel-mac problems? | crossed over | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-27-2006 08:31 PM |
Intel Mac works with boot camp! | Joe Sidoti | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-13-2006 01:01 AM |
Pro Tools on Windows on Intel Mac via Boot Camp | WaxTrax! | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-06-2006 07:27 AM |
