#31
Re: V-Control Pro as replacement for hardware surface
#32
Neyrinck's Facebook says they're working to resolve this. So it appears that it's a fluke.
#33
His site is up and running again...
#34
I apologize for the downtime! Thanks for bringing the problem to my attention.
#35
#36
Does anybody know why I don't have the edit page button on my v control pro? I have the edit window toggle button but not the pane with scrub shuttle. I'm also getting frequent lost connection messages from the hui/ni-fi software. Is that normal? I'm on windows pt 10.
#37
It's not normal to loose the connection. I've never had a lost connection, not even when I tested it through internet connected router.
Can you test your Wi-Fi connection without the controller app? Signal strength, drop-outs, slow downs, etc.
my blog:Tamas Dragon |
#38
All top notch. I have a super fast wifi router as well.
#39
Did you try disabling Bluetooth on your iPad and Maybe on your PC/Mac too? It appears doing this will have a positive effect on stability...and maybe connection.
Good Luck.. otherwise it must be something with your router or PC/Mac hardware and our settings. |
#40
One more thing to try. Make an ad-hoc network directly from your machine, so no router in the path and test it that way. With this you can be sure where the real problem lies.
If it's better, then you should check the router, etc.
003 control surface (As audio) & control 24 as surface | crizdee | ProControl, Control|24, Command|8 | 7 | 01-04-2016 12:30 PM |
Control Surface For Protools 10 Mackie Pro Control or Avid Artist Control | lberrios1962 | Pro Tools 10 | 18 | 05-26-2012 12:51 AM |
D-Control Es32 Control Surface No Sound from Headphone outputs | mark007 | Pro Tools TDM Systems (Mac) | 0 | 02-08-2012 07:03 PM |
Digi 003 as hardware control surface for Ableton Live? | bentropy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 09-02-2011 08:11 AM |
Mackie Control Universal or Tascam 1082 for control surface? | anders | Pro Tools TDM Systems (Mac) | 5 | 05-28-2007 06:12 AM |
