Old 03-02-2023, 11:09 AM
Treblecorp Treblecorp is offline
Default Adding metadata to pro tools export
Hi
Is it possible to add my publishing details to a bounced file prior to exporting to Wave format?
TC
Old 03-02-2023, 01:25 PM
BScout BScout is offline
Default Re: Adding metadata to pro tools export
Wave files don't store metadata like publishing. Your first problem
Old 03-03-2023, 05:33 AM
tamtamstudio tamtamstudio is offline
On Mac use Meta app, also in BWAV
Corrado Magalotti
Tam Tam Recording studio
Old 03-03-2023, 07:08 AM
Yes, meta data can be added to Wave files or edited, but is permission based: https://www.windowscentral.com/how-e...ion-windows-10
Also, updating computer name provides some ownership validation as well
Just doesn't seem possible when bouncing files. So maybe I need a separate service like Groove?
Old 03-03-2023, 09:54 AM
You don't understand what you've linked to. Those are local repositories.
BWF has metadata. Standard wave files do not. BWF stores its metadata in the iXML chunk. There are defined parameters for iXML. None of them are "publisher." iXML is not id3, etc like mp3. You can see all objects defined by iXML from the keeper of the standard:
http://www.gallery.co.uk/ixml/
Wave Agent is an iXML/BEXT editor for BWF files. You can see what it can edit (once again, not like an mp3 id tag)
https://www.sounddevices.com/product...gent-software/
In addition, BWF now has an axml chunk. That is only defined for ISRC at the moment.
Old 03-04-2023, 03:56 AM
That makes sense now, thanks for clarifying with that technical explanation. As I am learning, there are other ways to lock in the copyright and ownership rights. Enjoy your weekend
Export multiple clips, but adding handles stewie3128 macOS 3 01-01-2021 06:54 PM
FCP - export with timecode and metadata noiseboyuk Post - Surround - Video 5 04-22-2013 12:59 AM
Export without Metadata Lecherro Pro Tools 9 1 08-19-2011 08:46 AM
Adding Metadata to WAV files Voice Crafters 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-08-2009 03:17 PM
mp3 export is adding silence on files? bz lewis Pro Tools TDM Systems (Mac) 0 06-17-2003 09:34 PM
