Old 02-19-2023, 05:45 AM
Default UVI Falcon guru wanted
Long time user of Falcon and I know there's a fair few here as well. I normally don't have problems with this complex beast but recently I've come up with one. I have a goodly number of expansions from UVI themselves and have tried using them in self-made multis. No problem there except if I modify a program/instrument from an expansion by changing an effect in said instrument/program the changes aren't saved with the multi. Even if I do a specific save for said instrument/program the changes aren't saved and it's back to the way it was programmed from UVI.
Now if I create my own instrument programs, save them and use them in a multi and I make modifications to said instruments programs those changes are in the saved multi. I'm under the impression that a multi saves the state of the entire Falcon instance. Are the factory expansions locked so any changes can't be saved? I understand that you might not be able to overwrite the existing factory stuff but shouldn't one be able to modify and save to a new program/instrument and still have the original? Isn't that the whole point of 'save as'?
Jack
QAPLA!
Old 02-19-2023, 05:11 PM
bradch00 bradch00 is offline
Default Re: UVI Falcon guru wanted
Hey Jack,
Sorry it took me a while to get to this.... I have almost all UVI expansions and I get thrown off by the fact that some of the expansions (Drone for example) have their own FX sections in addition to the UVI Falcon Effects section.
Which expansions are you using so I can bring them up and try and work through it.
Pro Tools, Studio One Pro
2022 Mac Studio M1 Max 64GB-1TB NVME
OWC Thunderbay Mini (4TB SSD)
OWC Express 4M2 (4 X 2TB)
Interface: Presonus Quantum
Presonus Faderport & Faderport 8
Black Lion Sparrow Mk2 A/D, FMR-RNP-RNC, MIDI Xpress 128
BM5A, KRK VXT4, Equator D5
2020 Macbook Pro 16GB RAM, 512GB SSD Audio(mobile rig)
Old 02-20-2023, 04:50 AM
Originally Posted by bradch00 View Post
Hey Jack,
No problem with taking time to get back to me. I literally just got a reply back from UVI support an hour ago. From what they told me it goes like this: it turns out that the effects that are built-in to a certain expansion are only editable from the expansion gui and not the effects tab in Falcon itself. For example if an expansion has a reverb control as part of the gui that control takes precedence over the same control in the effects section. In this case that would be the reverb mix control. They say it's that way because certain controls are part of the script for that particular expansion. It shouldn't matter where the script gets it's input from - gui front panel or the effect in the Falcon effects tab.
I find it strange that if you go to the effects tab in Falcon and change that mix control it doesn't reflect in the expansion's gui itself. I mean - you go to the effects tab and can make changes to all the other controls and they save correctly but you can't make a change to the mix control and have that save correctly? I shouldn't have to worry if things will save correctly when I make changes. Shouldn't have to go to the main expansion gui page to tweak the reverb mix. Same thing with other controls.
In my case I was working with the Energy expansion. But it happens in others as well.
Again thanks for getting back to me.
Jack
QAPLA!
Old 02-20-2023, 07:01 AM
I didn’t realize that! Thanks for posting their explanation. Not sure I am happy about it, but at least it confirms my suspicion and is something to be aware of when programming it.
Old 02-20-2023, 08:15 AM
No problem. I'm not nuts about it. There's no reason I can think of that the script can't be changed to work logically. I've done enough programming to see it can be easily done.
Jack
QAPLA!
Plugin Doctor guru wanted musicman691 General Discussion 2 08-17-2022 10:52 AM
Anyone tried Guru yet? crizdee Pro Tools TDM Systems (Mac) 3 09-06-2005 10:05 AM
Mac Guru's - Can you tell me how to....? crow Pro Tools TDM Systems (Mac) 10 03-12-2003 09:50 PM
Studio Setup Guru's help wanted macman_001 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-30-2002 08:47 AM
looking for an 001 guru bigtree 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-26-2001 12:55 AM
