Reason sees Mbox 2 Pro... but PT 10 doesn't??
This is crazy: Mbox is available in other programs like Reason and Live, but not in PT. This was not an issue in PT 8.
In PT 10 I can only use the built-in Mac output! Does it have somethng to do with 'aggregate device?' Firmware? I am at a total loss here.
Mac (Retina 5K, 27-inch, 2020) OSX 10.15.7 PT 2021 |
Re: Reason sees Mbox 2 Pro... but PT 10 doesn't??
Hold the 'n' key while launching Pro Tools and then select the Mbox in the Playback Engine window.
You may need to download the updated drivers for your MBox.
Both posts are above correct. If the MBox is not a choice when lauch hilding the N key down you will need to install the latest drivers. If your updating from PT8 this is probably the issue. Previous installer's installed the driver along with Pro Tools as of PT9 the driver is a separate download.
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
PT sees the light? | ^Tripper^ | Pro Tools TDM Systems (Mac) | 0 | 02-23-2011 06:21 AM |
TDM Mix plus 3 24 I/Os only sees 16 I/Os | soundblaster | Digidesign Hardware & Software | 1 | 10-15-2008 11:58 AM |
Don't Know If I'm The Only One That Sees This But, | M2E | Pro Tools TDM Systems (Mac) | 3 | 05-08-2008 04:02 AM |
MBOX, Reason 2.0, macbook, pro-tools 7.3 (no reason plug in) | tahiti78 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 02-11-2008 08:11 AM |
OSX 10.3.7 sees audiomedia III, PT 6.2.2 doesn't | parcival | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-01-2005 11:24 AM |
