Old 02-28-2005, 11:13 AM
parcival parcival is offline
Default OSX 10.3.7 sees audiomedia III, PT 6.2.2 doesn\'t
I changed my powermac 400 mhz G4 for a powermac 800 mhz G4 Quicksilver
System preferences/sound: sees my digidesign HWlll
As soon as i want to launch protools 6.2.2 i get the message
that it cannot find thge hardware.
Does anyone knows what the problem is?
Parcival
gnoe.net
Old 03-01-2005, 11:24 AM
edgarbc1 edgarbc1 is offline
Default Re: OSX 10.3.7 sees audiomedia III, PT 6.2.2 doesn\'t
are you sure this machine never had any higher version
of PTLE on it? (like 6.4 or 6.7)
I have only had this problem when i "tried" the 6.4 upgrade
just to see what happens. I had to either:
1) go through all system/library and user/library files and
trash everything digi releated.
(if you still have your installer log then you can use this as a guide)
2) do a complete clean install of your OS 10.3.0 and upgrade
to the 10.3.7 version, then install PTLE 6.2.2.
(by the way there is a 6.2.3 upgrade free w/ auth code and multiclient
core audio works too)
ive a similar setup as you, amiii, ptle 6.2.2 cd
but i have successfully installed into an 8600 (xpostfacto) and a mdd 125G4 dp
good luck!
EBC
17" MBP i7, 4GB RAM, Profire 2626, PT-MP 8
PT sees the light? ^Tripper^ Pro Tools TDM Systems (Mac) 0 02-23-2011 06:21 AM
TDM Mix plus 3 24 I/Os only sees 16 I/Os soundblaster Digidesign Hardware & Software 1 10-15-2008 11:58 AM
Don't Know If I'm The Only One That Sees This But, M2E Pro Tools TDM Systems (Mac) 3 05-08-2008 04:02 AM
Everything Sees MBox2 except ProTools ByronD 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-06-2007 03:28 PM
OT xw9300 Only sees 2 gigs on ram XP Pro Brandonx1 Pro Tools TDM Systems (Win) 2 09-24-2006 03:33 PM
