Listenback / Talkback problem
I can't seem to get listenback input. I did everything the manuals say, but it won't work. Is the wiring also wrong like it was with older main-units ?
I tried connecting several dynamic and condenser mikes but still no result. Also the parameters in the main-unit utility-pages seem to be in order, what am I missing here??? The pots on the backside make no difference if I turn them up or down. Talkback works and slate works , why not the listenback??? |
Re: Listenback / Talkback problem
yes, it's sucessfull connection has so far eluded my wiring teams abilities.
Jules |
I have an 'old' version main unit and have succeeded in finding the listenback input but have found that the gain is exceptionaly quiet to apoint that when the main control room volume volume is turned up enough to hear it and you accidently press play or a talent plays a mic you will find your drivers embeded in the rear wall of your control room!!!!! One problem is that the dim on talk back dims the listenback/mains as well!!!!!! it works but use with caution!
Hope this helps |
Gain trims for talkback/Listenback are on the back of Pro control..
R |
You read this digi!!! In my humble opinion this is an example of bad engineering Guys, thanks for your reactions. |
No AAX Talkback plugin? No Problem - here's the fix! | mesaone | Pro Tools 11 | 13 | 09-01-2013 12:20 PM |
SC48 Talkback and another problem. | TheMAXX7 | VENUE Live Sound Systems | 11 | 09-18-2012 10:09 PM |
Listenback/Talkback. Auto sending an tone when recording. | WmSchwartz | Pro Tools TDM Systems (Win) | 4 | 08-09-2007 05:43 AM |
Problem with talkback | Pythagor | ICON & C|24 | 3 | 12-10-2005 01:00 PM |
C24 Listenback and talkback problem | RCKPROD | ICON & C|24 | 0 | 11-29-2004 12:07 PM |
