Problems loading and starting
Hi I'm a new user having used Logic for some years. Hope someone can help.
When I loaded the trial PT wouldn't start and shut down while loading plugins. After much googling I removed all the TR5 plugins (I didn't even know I had them) a parked them in "Plugins (unused) and it finally loaded. However once I'd got past this obstacle and started some tuition videos to give it a go, I found that as soon as I loaded any plugin at all - PT shut down again immediatley. I confess this was last week and I've kind of given it up as a bad job! I'm sorry as I'm going to lose my 30 day trial but actually I'm really busy right now. However I thought I'd better ask before I give up - is this a known problem and is there a magic bullet to sort this out? Seems crazy that this is industry standard software and I can't even get it to run. So far as I'm aware my iMAC should handle it no problem. |
Re: Problems loading and starting
Hi and Welcome
First off fead the https://duc.avid.com/showthread.php?t=300050 and please provide the necessary info like OS / PT version etc. Is this PT First? We need more info and what interface etc. You dont even say if it is win or mac.
Apologies - I thought I'd put all that info in my signature - obviously not, now hopefully rectified.
iMac17,1 Quad-Core Intel Core i7 Processor Speed: 4 GHz Memory: 32 GB OS Monterey 12.3 RME UFX+ interface - thunderbolt connected directly to iMAC via a 1m cable G-Drive Thunderbolt 6TB AMD Radeon HP 4K monitor connected via G-Drive on thunderbolt ProTools trial version (not First). |
Presumably 2021.12? Basic troubleshooting steps are in the link Chris gave. And since you already have a mess with plugins you should be trying moving *every* .aaxplugin file to the unused folder, and trash prefs. Pro Tools will automagically restore the default plugins when it starts. Still problems, test with built-in output (or whatever it is called) as the playback engine, test from a newly created admin account, test with your g-drive and external monitor and everything else not needed disconnected including the RME, and starting with a new empty session on just the internal fast SSD (which hopefully you are using anyhow for sessions).
Problems Starting Pro Tools 10.3.4 | Kafkaaron | Pro Tools 10 | 2 | 01-12-2015 05:54 AM |
Problems starting a new session | Dubsyk | Pro Tools SE and Essential (Mac) | 0 | 06-19-2012 10:23 PM |
2 big problems im having starting pt's | Dapinkobo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-16-2007 06:00 PM |
2 big problems im having starting pt's | Dapinkobo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-16-2007 05:29 PM |
Problems starting Pro Tools LE????? | roxbury | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-17-2002 10:28 AM |
