Old 01-13-2022, 03:51 PM
saraharmstrong saraharmstrong is offline
Default Unable to locate hardware issue
I've read several threads on here about this but none are helping. I recently had to reset my computer and reinstall pro tools and everything that comes along with it. I reinstalled my hardware driver and made sure it was up to date. It is plugged in and still pro tools does not pick it up and still says unable to locate hardware. I really am stumped on what to do.I have an m audio interface (that i reinstalled the correct driver for) and Pro tools 12 on my computer with windows 10. any help is appreciated.
Old 01-13-2022, 04:56 PM
Default Re: Unable to locate hardware issue
Hi Sarah
Welcome to DUC. Folks here kinda need exact info to help.
Unclear what you've tried. It would help if you explained that.
Make sure Windows sound control panel and other apps are *not* configured to use the M-Audio device.
Did you reboot the computer after installing the driver? Even if not specifically required, try it. Do you see the interface connected in the Windows device manager control panel?
What exact M-Audio interface? find a photo of it online if not sure and give a link to the photo here etc.
What exact driver have you installed? What does the Windows device manager control panel say the version number is for that driver is or give a link to exactly what you downloaded. "latest" does not tell us what exactly you are installing.
What exact version of Windows 10? in the System Control panel, e.g. "20H2" etc.
What exact version of Pro Tools 12? Only Pro Tools 12.6 and higher was officially supported on Windows 10. https://avid.secure.force.com/pkb/ar...tibility-Chart That does not mean you might not have gotten other versions to work.
"Unable to Locate Hardware" error and iLok issue amedouce Getting Started 2 05-14-2018 07:14 PM
"Unable to locate M-Audio hardware. Make sure your hardware is connected and turned o MerryD Pro Tools SE and Essential (Win) 8 08-02-2012 12:59 AM
Upgraded from 8LE to 9. "Unable to locate hardware" issue persists if no Mbox. Small Alien Windows 6 09-26-2011 02:18 PM
Help with iMac 10.4.11 and Digi 002 - Unable to locate hardware issue keylessguy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-22-2011 10:25 PM
unable to locate m-audio hardware. make sure your hardware is..works fine in ableton? pein Pro Tools M-Powered (Win) 2 10-07-2009 12:01 AM
