Old 12-15-2021, 08:30 AM
minister's Avatar
minister minister is offline
Default Hybrid Engine vs Non-Hybrid HX|2 in Post.
I have one system that is a Mac Pro 5,1 running High Sierra with 48GB of RAM and HDX|1 with 2021.10
And another system that is a Mac pro 5,1 running High Sierra with 40GB of RAM and HDX|2 2020.12.
Video is MXF.
If I run the 2021.10 system in Hybrid, even in small sessions (like 20-30 tracks) I have 9173 errors and alerts and hangs all the time.. Usually around Acon Digital Extract Dialogue or Deverberate. But other plugs too. It seems like I have to keep things smaller than before. It does work better when I put the HW buffer to 1024. But for a 30 track session?
Whereas, if I move these to the 2020.12 HDX2 and NOT in hybrid, the sessions run great.
I know some will say -- Get a new computer. That ain't gonna happen soon. And I have been over the optimization docs again and again. Also, checked on latest plugins.
Anyone else seeing this? Any fixes? Or, just wait for PT to sort it out in a new version.
Tom Hambleton CAS
Ministry of Fancy Noises
IMDb
Undertone on Facebook
Undertone Custom Sound Libraries
"Groupable markers would be epochal!"
-Starcrash
Old 12-15-2021, 09:42 AM
Default Re: Hybrid Engine vs Non-Hybrid HX|2 in Post.
Hm, both versions need 10.14.6 as the minimum. Not sure if that relates to your problem though...
I have no problems running either version on my 5,1 under Mojave but I don't use HDX so it might not compare.
My current work session is 600 voices and about 40 print tracks.
Old 12-15-2021, 11:48 AM
minister's Avatar
Thanks.
I was just informed by a great source that I should just bite the bullet and get a metal video card and upgrade to Mojave. I was hoping to avoid that.
I'll report back once I do that.
Tom
Tom Hambleton CAS
IMDb
-Starcrash
Old 12-15-2021, 01:14 PM
smurfyou smurfyou is offline
On my 5.1 I had much better performance after I installed a Metal card (RX 580 in my case). I don't have any experience with Hybrid though.
~Will
Old 12-15-2021, 01:43 PM
Originally Posted by minister View Post
Thanks.
Tom
It's very easy. Did it two years ago. Fairly cheap and was a 5 minute swap of the card.
Old 12-16-2021, 03:07 AM
Farhoof's Avatar
Farhoof Farhoof is offline
Even a single instance of realtime Acon Digital Extract Dialogue will eat half your CPU. It's best to use that tool rendered on the old 5.1 macs.
Regarding the Metal card, if you can get hold of specificaly this one: https://www.sapphiretech.com/en/cons...se-rx-570-8gd5 you'll need only 1 power cable and can use the other for the HDX cards without the use of splitters.
Old 12-27-2021, 03:41 AM
minister's Avatar
Just reporting back that I installed the metal cards and upgraded to Mojave on both machines. The cards came with power cables but they were the same ones I already had in the machines so I just reused them. After getting the systems updated and clean, I updated to 2021.12 on both machines. Everything has been running rock solid, I have more power available and it "feels" smoother (which could be my imagination). Shoulda done this before.
Anyone on High Sierra with a cheese grater Mac Pro 5,1 or 4,1, I recommend this upgrade.
Thanks everyone!
Tom Hambleton CAS
IMDb
-Starcrash
HTML code is On
The Hybrid Engine LDS Pro Tools HDX & HD Native Systems (Mac) 64 07-31-2021 09:17 AM
Pro Tools Standard & Hybrid Engine? Sparky1 Pro Tools 2020 2 06-29-2021 10:45 AM
Hybrid Engine thoughts LukeHoward Pro Tools HDX & HD Native Systems (Mac) 2 06-26-2021 06:58 PM
Hybrid engine effect on S6 basehead617 Avid S4/S6 8 06-08-2021 03:50 PM
What is the Hybrid Engine? loopzilla2 Pro Tools HDX & HD Native Systems (Mac) 31 04-22-2021 07:11 AM
