need help with volume automation
I apologize if I posted this in the wrong thread. I'm still quite new to ProTools. Just to let everyone know, I'm using a PC and using ProTools LE 8 so maybe the settings could have some differences. The problem I have is keeping a volume settings (is it called volume automation?).
I had a sound at a track that I deleted that had some volume settings that still show in the blank space which is at track 3. When I moved a sound on track 4 volume setting of the sound on track 4 got transferred to track 3. I want to still keep the volume setting for track 3 when I move the sound to it. Does anyone know what I should do? Also, lets suppose I have a volume setting I want at 3:00 and I am moving a sound around the track. How can I have it where the volume setting does not move with the sound? I don't want to have it permanent, but I just want to have it where I have it both ways where the volume setting moves with the sound or stays in one area. Thank you! |
Re: need help with volume automation
highlight the volume automation and delete
Or alt+click on the dots in the automation lane
@theaudiogeek | www.EPICSounds.ca | www.AudioGeekZine.com | www.HomeRecordingShow.com | |
@audiogeekzine
Thanks for the reply. I don't need help with deleting the volume automation. What I was trying to do was keep the volume automation on a blank track and move a sound to the blank track without destroying the volume automation on the blank track. |
you'll have to remove the original automation before moving the region.
You can move your sound region to a blank track, then high light the automation (from wherever it is), hit apple c or copy, then go to the track your sound region is on and apple v or paste your automation into that track.
Volume Automation.. | thierryhenry | Pro Tools 10 | 5 | 01-05-2013 12:46 PM |
Converting Volume Automation to Clip Gain = Higher Volume! | EricWillhelm | Pro Tools 10 | 8 | 11-01-2011 11:12 AM |
FCP, OMF & volume automation | idris | Post - Surround - Video | 9 | 09-03-2010 08:06 AM |
volume automation | cpt | Pro Tools TDM Systems (Mac) | 9 | 02-12-2010 01:30 PM |
Volume Automation | Bezo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 12 | 11-10-2003 02:23 PM |
