Digi 002 rack firewire problems
Hi folks,
Long time protools user, first time post on these forums... Trouble is: My Protools can't see my hardware on startup when it is switched on and connected. On the back of the rack the little green LED for the firwire conncetion lights up when the unit is powered up and switches off almost immediately after. When I switch the unit off and on again, the light comes back on only to switch off again... I had this problem before I upgraded to version 7 and it disappeared for a while with the upgrade, til now. I have not used protools in several months, and am very frustrated for the lack of continuity... FYI, I'm running: Protools LE 7.1 / Digi 002 rack/ Mac G5 MP 2.5ghz/ OS 10.4.7 /3.5 gb ram I hope you can offer some insight into my nightmare... Thanks in advance, Charles
Mastery through ignorance. |
Re: Digi 002 rack firewire problems
Charles, it looks like you suffer from the well known POWER HARNESS problem (you can do a search on the DUC).
Solution: Contact DIGI Support they will send you you a free replacement kit. This will solve the problem. P.S. if the replacement kit doesn't solve the problem then you might have burned out your Firewire ports on the 002 (due to hot plugging). In this case you must sent in your unit to a DIGI approved repair shop ($). But more likely it's the Power Harness thing. |
Issues with FireWire on Digi 002 Rack | obiwanws2 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 39 | 08-09-2010 11:35 AM |
PTLE 8 + iMac + 003 rack + firewire 800 ports, problems | sos4e | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 23 | 09-05-2009 07:11 PM |
002 Rack - firewire problems | elankf1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-26-2009 09:37 AM |
Digi 002 Rack Firewire problem | Tomibrod | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 12-21-2007 10:08 AM |
DIGI 002 RACK + FIREWIRE HUB = PROBLEMS? | waterbedman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 12-07-2004 12:53 PM |
