#7001
Re: Free Windows 10 Audio Workstation Build and Tweak Guide
I did, thank you.
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones Owner: Dragon Rock Productions LLC |
#7002
Re: i7 Builds - Specs and Results
Hello,
I am considering a new computer build. My system is very old at this point. I want to start with finding if Thunderbolt 3 should be a desired part of the build. I haven't seen TB3 mentioned with folks that are building with the new Intel i9-12900k cpu's and DDR5 memory. Should it be a high priority when considering a new build? I have built many systems myself in the past but it has been a while. Also I am considering purchasing a new interface so thought maybe TB3 would be the way to go. I am a hobbyist so don't have a business studio or anything like that. My other concern is about getting a new maybe 32" or so monitor. I have two old 24" DVI type connector monitors and I thought I would upgrade that. My old tired eyes aren't what they used to be. Any suggestions regarding monitors now a days. I would appreciate your thoughts on it. Edit: I did find this with a very fast search, I didn't know TB4 was even out there. This example has a header on MB but not inline connector built in. https://www.asus.com/us/Motherboards...690-PLUS-WIFI/ This will be DAW only no games. Edit2: I looked at this motherboard also which has header connection on the MB for TB4 so I will guess having Thunder Bolt will require a addon card. This Gigabyte board also has MB header pins for TB4 https://www.gigabyte.com/Motherboard...STER-rev-1x#kf This MB also only has two PCIE4 expansion slots and one gets disabled if you use all the M.2 connectors on the MB. I'll keep researching. Thanks for any guidance.
"So it goes", Kilgore Trout Last edited by ValkRider; 04-20-2022 at 12:12 PM. |
#7003
Here's a 12th gen MB with Thunderbolt4: https://www.newegg.com/p/N82E1681314...quicklink=true
and a Thunderbolt 3 audio interface: https://www.presonus.com/products/quantum-2626
Desktop build: PT 2020.5 / Win 11 / i9-11900K @ 5.1GHz / 64GB / 4TB NVMe PCIe 4 / Gigabyte Z590 Vision D / PreSonus 2626 Laptop: PT 2020.5 / Win 11 / i5-12500H / 16GB / 1TB NVMe / Lenovo IdeaPad 5i Pro / U-PHORIA UMC1820 Ancient/Legacy (still works!): PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI 001 Click for audio/video demo Click for resume |
#7004
Thank you very much. I had not seen that Gigabyte MB. I was wondering if air cooling like a Noctua unit is sufficient with the 125watt CPU's. I would prefer air cooling over water. I guess I have a inherent mistrust of having liquid inside a computer. I like the Fractal Design cases and have looked at the Define 7XL and their Meshify 2. Lots of internal fan possibilities for a good push pull air flow setup. A lot more to research yet.
"So it goes", Kilgore Trout |
#7005
Even have a 300MHz all core OC going with some undervolting on the i9 - it can thermal throttle slightly on synthetic loads (like Prime95) but extremely rarely in PT use. The only example would be a long all-core demanding offline bounce, but it's not a significant issue, the one-core boost I get from x52 all P-cores in PT is more than worth it.
Windows 11 23H2, Intel i9-14900KS, MSI PRO Z690-A D4, 64 GB DDR4 4000MHz/CL18, Corsair HX1000, 1TB M.2 PCIe 4.0, 5TB M.2 PCIe 3.0, 2TB QVO, 2x6TB WD Black, Noctua NH-D15, Fractal Design Define R6 + RTX4070 - PT Ultimate 2024.3 Used to be/ Spare/ DAPS: Mac Pro 4,1 upgraded to 5,1 3,46Ghz 12 Core, 96GB RAM, OS SSD and Sata3 Audio SSD, macOS Mojave, PT Ultimate 2021.10, DAPS 3.7.1 HDX2, MTRX Studio & DAD MOM, HD I/O 16x16, Apogee AD/DA 16X/X-HD and ICON D-Command ES. |
#7006
I've finished my new build (Dedicated Pro Tools only Rig...Running PT11HD v 11.3.2). Motherboard: Gigabyte Z690 AERO D. CPU: Intel Alder Lake Core i9-12900K 16 Core/24 Thread. CPU Cooler: Noctua NH-D15S (with two fans, push/pull) Extra Fan. RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) 2 slots free. Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples). 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (System Win 11). PSU: Corsair HX Series HX850 Platinim (Modular). GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4. CASE: Fractal Define XL R2, Extra Fans. I have only done a test run with Pro Tools so far, but wow this thing kicks ass! I can't speak highly enough about the Fractal Computer Case, running 5 fans (7 mounts) and is extremely quiet. Solidly built and shields EMI very well too.
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O Last edited by zedhed; 05-16-2022 at 09:58 PM. |
#7007
#7008
I couldn't bring myself to go the subscription route and 11 does everything I need. It's been incredibly stable and is as much so on Win11.
One day I might move up but the money I've saved by sticking with what I've got, has gone part way to enabling this build. Edit: Thinking about it, it's probably completely paid for it.
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
#7009
FWIW I'm still with a perpetual license and pay the upgrade tax. Reinstatement is still possible I think, at least through 3rd parties (to keep the perpetual and get back to the upgrades).
#7010
Best Core 2 Series Desktops-Results and Specs | sunburst79 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2416 | 02-19-2013 07:49 PM |
new to pc builds | chazc080488 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 10-18-2011 07:10 PM |
any p45 builds | fofif5792 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-09-2008 12:47 PM |
OSX "builds" | Richard Barrie | Pro Tools TDM Systems (Mac) | 2 | 10-18-2004 08:37 AM |
