Old 09-20-2023, 06:46 AM
theodd theodd is offline
Default PT 2023.6 & Eucon 2023.6 Work Perfectly Natively, but no connection under Rosetta
Hi all,
Long story short, been using an S3+Dock with Pro Tools / Eucon and everything works perfectly running natively.
Problem is, I just bought Altiverb for an upcoming project and did not realize that it is not yet Apple Silicon compatible (somehow).
Audioease support suggests running PT in Rosetta mode but when I do that, the Eucon <-> PT connection is broken so the control surfaces don't work. The surfaces show up in Eucon and are an added under 'My Surfaces'. But in PT, the Eucon indicator light is off.
Is there a Rosetta trick to making this work? Or did I just waste a ton of money on Altiverb?
Thanks
Old 09-20-2023, 07:23 AM
its2loud its2loud is offline
Default Re: PT 2023.6 & Eucon 2023.6 Work Perfectly Natively, but no connection under Rosetta
Originally Posted by theodd View Post
Hi all,
Thanks
You have to enable Eucon the old way under Rosetta.
Setup > Peripherals, and click the Ethernet Controllers tab.
And yes, you just wasted a ton of money on Altiverb.
Old 09-20-2023, 08:56 AM
Ouch, why so harsh on Altiverb? Jeez.
Will try what you suggested.
Old 09-20-2023, 09:27 AM
Ok, so just checked Peripherals -> Ethernet Controllers and EUCON Control Surfaces is checked.
I've attached some screen shots of the various EUCON application settings.
I think the culprit is in the System Settings of Mac OSX. It's showing Network Interface: Thunderbolt Ethernet but the Launch Status is "N/A".
Again, if I boot PT natively, the S3 and Dock are rock solid. Any ideas folks?
Old 09-20-2023, 12:21 PM
BScout BScout is offline
Are you using it with Pro Tools or not? That last picture shows you using it as a MIDI/Mackie device with Ableton, etc. That would make it unavailable for Pro Tools.
The system preferences > Eucon is only for Mackie/MIDI emulation.
"Eucon" programs are only done from the Eucontrol app itself on the Applications tab. (I would check if Pro Tools is added there and if it is, remove it and re-add it.)
Pro Tools Ult 2024.10.1, HDX 2, MTRX/SPQ, SyncHD, DNxiQ, RME BBF Pro + MADIface ProS1 x 2, Fire Max11 x 2, Dock, iPad Air5 Mac Mini 14,12, 12 core, macOS 14.7.1RAM 32GB, SSD 4TB, GPU 19 coreQNAP TVS-872XT 148TB TB3
Old 09-20-2023, 12:55 PM
Thanks
You asked.
Old 09-20-2023, 04:57 PM
Hey thanks for trying to help. Yes, I'm using with Pro Tools with the S3 & Dock. But also Ableton and Logic. When I'm running PT Natively (not Rosetta), the way it works is whatever app is focused in Mac OSX, the S3/Dock switches to that app. I love that functionality and it works really well.
See new screen cap attached to show that PT is the focused app in the EUCON app. So the issue remains on my system, S3/Dock work perfectly everywhere (Pro Tools Native, Logic, Ableton). But for some reason, running PT under Rosetta, PT and EUCON can't find each other it seems.
File Type: jpg Screenshot 2023-09-20 at 6.50.05 PM.jpg (22.1 KB, 0 views)
Originally Posted by its2loud View Post
You asked.
Wow bud, you seem very cool.
Old 09-20-2023, 07:10 PM
You might want to try a clean uninstall and then an install again. (Clean uninstall is done by running the Eucontrol installer and checking the uninstall option, reboot after that, then reinstall running the Artist/Dock/S3/S1 option from the installer)
Old 09-21-2023, 07:58 AM
Ok, so further testing here...in both System Settings and the EUCON app I checked off 'Enable as External Workstation' and partial functionality came back.
The S3 an Dock see Pro tools now, status light comes on, but I have no meters on the surface working and the motorized faders do not work. I can record automation. But they do not play back the automation on the desk. No meters on the desk and the lights for the various button states (like automation) do not work.
Clearly this is not the way, but why does enabling this 'sort of' work?
File Type: jpg Screenshot 2023-09-21 at 9.50.04 AM.jpg (19.1 KB, 0 views)
EUCON 2023.6 Released EddieJones Avid S1, S3, Dock and Control App 21 07-27-2024 06:51 PM
EUCON 2023.6 Released EddieJones Avid S4/S6 3 09-14-2023 03:26 PM
Eucon 2023.6 Crashes often when using PT 2023.3 Selle Sellink Pro Tools 3 08-06-2023 03:29 AM
Apogee Rosetta 800 FW on new M2 Mac PT 2023? trav711 Third Party Interfaces 1 06-24-2023 08:36 PM
Today's AIR FX and Instrument 2023.3 updates re-install 2023.2! off the wall Pro Tools 9 03-28-2023 11:33 AM
