Just installed 003_MIDI_MODE_34512 No 003 showing
I installed the MIDI mode firmware update & now PT cant see my DIGI 003 I get the error....
error occurred while trying to load the controller personality "003" PT starts up and runs sessions but the 003 screen is blank & the faders dont move. everything was fine before I installed the MIDI mode update (003_MIDI_MODE_34512.dmg) any suggestions? I tried to install it a few times & got the same result. Should have just left well enough alone! |
Re: Just installed 003_MIDI_MODE_34512 No 003 showing
It sounds like the controller personality is corrupted. You have a couple options - you can do an uninstall and reinstall of Pro Tools, making sure to trash the Controllers folder in the Pro Tools folder before reinstalling - this will reinstall a new controller personality.
Alternately if you know someone with the same version of Pro Tools they can send you just the 003 controller file and you can replace the one in your Controllers folder with it. Please trash preferences after doing either of these. |
Can I get that file from DIGI?
I,m on PT 7.4 cs3
I have confirmed that is what my 003 bundle file is. There are other Bundle files in there .e.g. 002. / command 8 etc... the total Controller file is about 40mb. If its any good to you, i can upload it. I suspect that you may be on PT8 though.. |
Thanks! Im on 7.4 cant remember what CS version it is though, please upload it I had my rig in perfect order until this!
Okay here it is, its a zip but this is Mac forum so should be okay..... click the oblong grey bar, it reveals the code for download. http://www.filedropper.com/controllerscopy Also as Digi has pointed out, remember to Trash preferences, (manually) .. or..Digi has a utility on their site, if you do not already have it. And there is this freebie which is good. http://www.jcdeshaies.com./ Any problem, post back. |
Thank you! I know Im slow @ responding, Ive been concentrating on overhauling my work studio & havent so much as turned on my home set up in weeks! Ill try this & post back soon! Thanks again!
Spoke too soon, the link is dead, it just takes me to the main page of file dropper. Can you re-up? |
Installed RMX and SONIKSYNTH and theyre not showing up | wonderlover | Virtual Instruments | 2 | 08-08-2007 10:25 AM |
Installed RMX and SONIKSYNTH and theyre not showing up | wonderlover | Virtual Instruments | 0 | 08-07-2007 11:32 PM |
Installed plug-ins not showing up in Pro Tools. | ndaudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-05-2006 12:59 PM |
Installed Plug's not showing up??? | kitana_one | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 03-19-2005 10:14 AM |
waves ver 2.8 installed but not showing up | paxrec | Pro Tools TDM Systems (Win) | 0 | 07-04-2001 10:51 AM |
