Old 10-22-2008, 10:11 AM
Esus Esus is offline
Default Time Code Ruler problem
Hi All:
Can someone refresh my memory on how to clear the TC Ruler in the Edit window? Time Code 1 is grayed out, and I can add or clear any of the other Rulers except that one.
What's happening is the TC Ruler has expanded and I'm getting a blue arrow which is bringing me back to the original insertion point. I want to clear that.
Thanks in advance!
Old 10-22-2008, 11:06 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Time Code Ruler problem
Originally Posted by Esus View Post
Hi All:
Thanks in advance!
Its greyed out because its the ruler you have currently selected! select bars:beats then you can remove the TC ruler.
Your problem more sounds like you have selected "timeline insertion follows playback" (with keyboard focus selected? thats the a-z box top left under the mag glass, Press "N" on your qwerty keyboard and you should be back to how you want it)
Chris
Producer, Engineer,
www.ukmastering.com
Old 10-22-2008, 12:39 PM
Originally Posted by crizdee View Post
Chris
I tried opening and closing every other ruler parameter, even "all" and "none". Time Code stays and is still grayed out. Tried Keyboard Focus and selected/deselected all boxes in Operation prefs. No change.
I still have an expanded Time Code ruler which I cannot close out of either by itself or by trading with another ruler...
Old 11-03-2008, 10:24 AM
If anyone's interested, I solved my problem by trashing all my preferences and starting over. Looks like the problem was just a glitch. I needed to reset all my personalized settings, but ten minutes after the trash, I was back.
PT8 absolute time ruler jasbart 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-14-2011 04:21 PM
Current Time Code / Spot problem fiddlecat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 03-15-2009 08:58 PM
QT time code won't match to PT time code in PT LE jah-d Post - Surround - Video 4 07-28-2006 11:44 PM
midi time code problem blacceaser MIDI 0 11-25-2004 09:58 AM
Track Transfer won't transfer (time code problem) apetrocelli Pro Tools TDM Systems (Mac) 4 10-17-2000 02:49 AM
