Old 04-10-2008, 10:42 AM
rboos4 rboos4 is offline
Default neo assertion errors help
I opened a new track to record electric guitar, it would record but no data would appear. Then the sytem would not allow me to stop with the space bar or with mouse control. I had to quit protools, and even that had trouble. This happend four or five times.
I might have my workspace allocation setting wrong. I am running a external hard-drive firwire. I am using both the mac and the external hard-drive.
Confused about the A and the V, and which one should be set to record and playback in the workspace.
the error reads
Could not complete request because
Neo assertion in /volumes/development/vb cliff/enviornments/alone/../../../../source/(neostreamable.cpp line 2247
any ideas?
Old 04-10-2008, 11:19 AM
Slim Shady Slim Shady is offline
Default Re: neo assertion errors help
There's a little section in the "General Troubleshooting" thread about deleting Database and Volume files - check that out and it should get rid of the message.
As far as the drives go, you should record all your session data to the external, avoid tracking to your Mac HD if possible. Any drive you want to record to should be set as 'R' in the workspace.
Old 04-10-2008, 12:08 PM
thanks dude, I will check that out.
too clarify
externall should be set to R only
and the mac to P only
the a and v throws me off, there is two options for both.
thanks again!
Old 04-10-2008, 01:25 PM
Can't find the thread
Old 04-10-2008, 01:53 PM
found the thread but its not clear as to where I can find the information. The links do not have the info in regards to trashing database files.
Old 04-10-2008, 02:07 PM
DigiTechSupt's Avatar
OS X Setup and General Troubleshooting
Databases and Volumes
This step can be useful when receiving random 'assertion' or 'neoaccess' errors, especially when recording or saving.
-Delete the Digidesign Databases folders on the first level of all mounted hard drives, then delete the "Volumes" folder in MacHD > Library > Application Support > Digidesign > Databases.
-Empty trash, then restart the computer.
Avid Audio Tech Support
Support FAQ
Old 04-10-2008, 04:15 PM
"first level of all mounted hard drives"?
I am running LE with Mbox 2 MINI with a MacBook and A Lacie External.
I might have posted in the wrong section.
Will the same advice apply?
Old 04-15-2008, 04:31 PM
ouib ouib is offline
k
so im using Pro Tools LE 7.3 with Mac OS X or whatever its called, and im having the same problem as the guy who posted about having start up issues. everything was working well when i first was using the software, however after about 5 or 6 days into using it, i began to get this error message, i am not sure what the error message is because about 3 three seconds after the message is displayed Pro Tools shuts down and gives me the "relaunch or send error report to apple" window.
i have tried the uninstall and install again route, and that did not work...so...how do i resolve this issue...itd be nice to be able to get back into recording
Old 04-15-2008, 04:34 PM
Phil Ogden Phil Ogden is offline
Trash Prefs/Databases as discussed above. If that doesn't work, post back with full system details.
help us help you
http://www.myspace.com/philogg
Old 04-15-2008, 04:47 PM
woo! thanks man, things are working now, or at least its letting me start up the software, now i just gotta hope nothing else goes wrong
thanks
assertion errors how to fix garnoil Pro Tools TDM Systems (Mac) 12 12-10-2013 06:13 PM
assertion errors that aren't going away dobatron81 Pro Tools TDM Systems (Mac) 1 03-20-2009 07:09 PM
Assertion errors? DarthFader777 Post - Surround - Video 10 02-17-2009 11:18 AM
Assertion Errors? Chaka015 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 06-26-2007 09:51 AM
Anyone else get Assertion Errors? beggehorn Pro Tools TDM Systems (Win) 4 12-02-2003 12:53 AM
