Plug-In Not Appearing on List
I'm using Protools LE 7.3.1 on a Mac Mini 1.66 Ghz 2 Gig Ram, La Cie HD.
The problem is that I just installed PT and Guitar Rig 2 but GR2 is not appearing on PT when I create a new track and select for it under the drop-down window that comes up with all of those other things (dither, eq, delay, reverb, etc.). It's just not there. In the manual of Guitar Rig it says to just select it from that menu and use it. The PT literature says consult the plug-in manual. LOL So, has the plug-in got to be loaded somehow? What the heck do I do? Thanks! Dana ;0 |
Re: Plug-In Not Appearing on List
Hey,
Are you sure you got the right installer (PPC or Intel)? |
Installer for the Guitar Rig? My OS is compatible distinctly to the Protools version I am using, yes. The Guitar Rig software simply comes with 'Mac' or 'PC' and it appeared to have installed correctly. It will standalone and operate well. It simply does not appear on my plug-ins list when I try to use it. Any ideas? Thanks. Dana |
What he's asking is - are you using the proper Mac installer for your computer. Most newer Macs are based on Intel processors and require and Intel version of the plug-in. If you're using a PPC installers, it's not going to work on an Intel machine.
Looks like you need version 2.2 to work with Intel based Macs.
MIDI Controllers Not Appearing In Peripherals List | TaoMokoda | Pro Tools 10 | 15 | 06-14-2024 08:55 AM |
MDW aax V5 not appearing in list??? | PT user | Windows | 2 | 08-25-2013 01:35 AM |
Time Delay between Clicking Track List and appearing in midi Editor | Jeanpaul | Pro Tools 9 | 22 | 09-21-2011 10:57 AM |
Tracks in list not appearing in edit window | PhilBuckle | Pro Tools TDM Systems (Mac) | 1 | 11-26-2008 05:32 PM |
Plug in instruments not appearing in list | megalaser | Pro Tools M-Powered (Mac) | 0 | 12-01-2006 07:11 PM |
