Ok, lets try this again....lol
Just migrated to Pro tools from Cubase. Picked up the NEW Mbox with PT LE 8.0.4 along with Toolkit 2 last Fri. Problem I'm having, when I import files into ProTools it's not at the same sample rate as was recorded, in other words, it plays back at 1/2 speed. I opened up one of my Cubase projects, chose the MBox as my Interface and the entire project is now at the wrong sample rate as well. So I switched back to my other interface (my trusty line 6 UX2 lol) and sample rates in Cubase returned to normal. I'm sure it has something to do with setting up the MBox, like I said, same problem when I imported the Demo file of the song into PT. I have tried importing MP3 files and Wave Files. MBox is USB 2.0 about a 4' cable (the one that came in the box). Tried switching out cables to no success. I've tried creating numerous projects at different sample rates but it hasen't solved the issue. I've done the optimization guide, and searched the knowledge base as well as 2 days of non stop googling to find a fix. Disable Host is unchecked and IE8 is removed from my computer (it barely ever goes on line anyways). I have Quicktime on my computer but not iTunes. Onboard audio is disabled. I have 2 HDs on my computer. Drive C: is my OS and Drive E: is my audio HD. Both HDs are Sata 32 mb cache. Lots of room on both HDs. The MBox is currently set up at 24/48 with a buffer size of 512.. A push in the right direction would be greatly appreciated :) My specs are in my sig below. Thanks in advance :) Gabriel
MBox 3 | PT LE 8.0.4 | Toolkit 2 | AMD Phenom™ II X4 3.2 Ghz with Arctic Ice | Seagate 500 gig (OS) and 1.5 Tb (Audio) HDs, 32 mb cache each | Gigabyte MOBO | Windows 7 64 Pro | 4 gigs Kingston DDR2 1200 Hyperextension Ram | 750 watt power supply | Antec Sonota 111 case | Dual 24" monitors |ATI Radeon Graphics card | Korg Triton Extreme | Korg M3 | Guitars |
I'm having similar problems (thread in the Mac area). Is all you audio at the wrong speed? Or is it just when you import audio and play it back in pro tools? If you play a mp3 in media player or something?
![]() Quote:
Best Gabriel
Ok, I guess it's the same problem I have then. I've tried everything I can think of (including testing on a different machine) and still the sound is always slow thru the Mbox. Mine is packed for return to the shop, but I'm still hoping Digisup will come back with a simple solution (a "reset hardware" or something..)
Well i'm pretty sure it's a driver/firmware issue. I work in the computer repair, custom build and software support industry so I think i know what I'm doing when it comes to PCs lol. I've spent from Fri evening till this morning googling for solutions. LOTS of folks are having the exact same issue with no resolve.
Have to remember, it's a brand new piece of hardware so glithes are to be expected. I just hope it gets resolved soon :) Gabriel
Yes, but what I find odd is that it's like that on my mac so a driver issue should have been spotted in testing. I guess it could be the firmware, but then a replacement would probably be quicker than waiting for an application to reset/update the firmware I think. I'd realy like to hear if digi techsup has had any luck reproducing this!
Ok, just got off the phone with Digitech support (very proffesional and helpful btw). Avid is aware of this issue and the problem is NOT on our end. It's fualty unit/s. Like I was saying, new piece of hardware and we can expect glitches. I suggest you call up support ASAP and they will get you straightened out:)
Gabriel
well just bought the new m box 3 and i am having similar issues , when i set a session up at 96 khz and import a instrumental no matter what sample rate i select it plays back in slow motion any thing above 48 khz plays sped up even when i set up a session at 44.1 and import a instrumental at 44.1 it still plays in slow motion can anyone help me with this situation is anyone else experiencing this ???? is this a defect within the m box 3 ???? and will avid replace it if it is ???? i purchased it from guitar center and they say they wont replace it or refund my money because i already installed the software , therefore will avid take care of it ???? from what i understand i only get one support call ????
MBox playback at wrong sample rate ...... | Gabriel_S | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 10-03-2010 04:59 AM |
DIGI 001 to HD192 Sample Rate plays back wrong... | Nathan W. | Pro Tools TDM Systems (Mac) | 1 | 05-15-2006 10:21 PM |
Midi plays back wrong sometimes | KimSira | Pro Tools TDM Systems (Mac) | 1 | 02-06-2006 06:26 AM |
Transfer HD TDM to 5.1 TDM plays back wrong speed | MarkB | Pro Tools TDM Systems (Mac) | 1 | 03-26-2004 05:32 AM |
Pro tools plays back wrong audio | David Carstairs | Pro Tools TDM Systems (Mac) | 2 | 06-28-2001 07:46 AM |
