Old 06-14-2012, 03:01 PM
deardaddy deardaddy is offline
Default rec + play does not work anymore
Since I upgraded to 10.2, the action of hitting "rec" and then "play" button on the D-command does not function anymore ("rec" turns on but extinguish as soon as I hit the "play" button).
I can hit play" and then "rec" but not the opposite.
I can do it on the mac keyboard but not on the console.
Hope I was clear in my explanations ;-)
Any idea ?
Thanks for your time
Pascal
Pascal Zander
Stand up
Audio recording & post
www.standup.be
MacPro 2019 16 Core
10.15.7
PT Ultimate 2021.3.1
HDX 1
D-Command
Old 06-15-2012, 02:27 AM
Stig Eliassen's Avatar
Default Re: rec + play does not work anymore
I have seen that a couple times in 7.4, and trashing PT prefs fixed it.
Old 06-15-2012, 04:49 AM
I did not try that, I'll trash the prefs and see if that helps.
Thanks
Pascal
Pascal Zander
Stand up
www.standup.be
MacPro 2019 16 Core
10.15.7
HDX 1
D-Command
Old 06-16-2012, 11:23 AM
Greg Malcangi Greg Malcangi is offline
Don't know if it's the same on a d-command but if you try this on a d-control with "edit" selected on the edit/timeline button, you get exactly the same results you're reporting. Switch the button to "timeline" and all works as expected. The edit/timeline button switches playback when using the play button (as opposed to the spacebar) to either play from the playhead or play the selection.
G
Old 06-16-2012, 11:29 AM
I trashed the prefs and it worked but I'll have a look at the button Greg is mentionning, I don't have the console in front of me but I'll check.
Thank you for your time.
Best regards from Belgium,
Pascal
Pascal Zander
Stand up
www.standup.be
MacPro 2019 16 Core
10.15.7
HDX 1
D-Command
Old 06-17-2012, 01:53 PM
diamondschwin diamondschwin is offline
Pascal,
Where did you get the desk for your icon? it looks to have 2 flat wings with a rack on the lower left. Hard to tell from the pictures.
Max Holland
Producer / Re-Recording Mixer
Nashville / NYC
MKD Creative
Old 06-17-2012, 02:25 PM
Greg : the Edit/t-line switch does the same on the D-command, when the switch is in Edit, the rec button does not work "normally".
Max : The desk is designed by me and built by a friend of mine here in Belgium, the rack on the left side is not attached to the desk.
There are 2 flat wings so I can have 2 people sitting next to me if needed.
The desk is made of 5 layers of MDF (I don't know if it is the same name in english).
Pascal Zander
Stand up
www.standup.be
MacPro 2019 16 Core
10.15.7
HDX 1
D-Command
pt 9 wont play anymore!!?? scopelinio macOS 9 03-21-2011 03:04 PM
Can't work in 88.2 anymore on PT9? nickbradbury macOS 6 03-13-2011 06:07 PM
can't play sound on my computer anymore wreckthisplace 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-29-2005 11:07 AM
can't play session anymore deardaddy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 07-03-2003 03:14 AM
Digi won't play CDs anymore Armando 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-09-2000 09:09 AM
