Old 10-26-2021, 01:02 PM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Monterey is now available
Originally Posted by lucas f. View Post
Anyone on 2021.3 , using the video engine on am m1 mac mini made the monterrey jump?
Video engine is not working on Apple Silicon yet. Maybe next release whenever it is.
Janne
Old 10-27-2021, 02:42 AM
lucas f. lucas f. is offline
Video engine is working with 2021.3 on silicon...I use it almost everyday...Avid has broke that after...
Envoyé de mon SM-G960F en utilisant Tapatalk
Old 10-28-2021, 03:23 PM
BCnSTL's Avatar
BCnSTL BCnSTL is offline
Reloaded my M1 MacBook Air with Monterey.
Installed iLok, PT 2021.3.1 - it launched.
Installed WAVES v13
Installed AVID Plugin Bundle
Installed ToonTrack VIs
PT hangs on launch during plugin scan (same as it was doing before).
Installed 2021.10 - same.
Extremely frustrated. Oh well.
2023 M2 Pro - MacBook Pro 16 -16GB RAM - 1TB SSD.
2021 Razer 14 Ryzen 9 5900HX - 16GB RAM - 1TB SSD.
PT 2024.3 Native
Life is like an Analogy.
Old 10-28-2021, 03:35 PM
JFreak's Avatar
Get rid of WavesHell and try again
Janne
Old 10-28-2021, 03:55 PM
Pete Gates Pete Gates is offline
Waves V13 running fine here. It's actually some of the Avid plug-ins that aren't, particularly the pro ones, Audio Ease Speakerphone doesn't work (which they do warn about to be fair) and RX8 advanced plugins will open but the ones I've tried here crash when you try to render. Don't know about RX9, was holding off upgrading due to unrelated problems people in other threads say they're having with RX9.
Pete
  #16
Old 10-28-2021, 04:25 PM
BCnSTL's Avatar
The scan gets stuck on Eleven MKII - if I remove it just gets stuck on another, then another, then another.
PT 2024.3 Native
  #17
Old 10-28-2021, 04:55 PM
Ben Jenssen's Avatar
This is probably worthless, but anyway;
Many years ago I noticed that the "loading plugins" info on the splash screen seemed to not show the plugin that was being loaded, but instead it showed the plugin that had finished loading. So, I don't know if this is still the way it works, but if it is, then it would be the plugin alphabetically AFTER Eleven that was the problem.
  #18
Old 10-28-2021, 05:35 PM
GoButtonGuy GoButtonGuy is offline
For those wanting/needing to troubleshoot this remove all plugs and add them back one at a time until you find the culprit. It’s brutal but it gets it done. In my experience it's almost always one of the bundled plugs. Waves is always ready for the new OS well before Protools.
What happens in Vegas, we make happen...
  #19
Old 10-28-2021, 07:36 PM
raypiasecki raypiasecki is offline
M1 MBPro 16gb
2021.7
macOS monterey
didn't upgrade to 2021.10, too scared to
some plugins on inserts on channels cause beachball crash, some don't
save often guys
some plugins don't crash
anyone have luck with 2021.10 on Monterey?
  #20
Mauricemeow Mauricemeow is offline
I was able to launch pro tools 2021.6 in Monterey 12.0 but was unable to open an existing project...'cause it was set at 44k sample rate, while another project at 48k did open
Has anyone tried Pro Tools 2021.7 on the Monterey Betas? off the wall macOS 28 11-17-2021 10:21 AM
