Old 10-05-2021, 09:44 AM
Angela15 Angela15 is offline
Default Latency with Mix Pre6 as audio interface
Hi all
Could anyone share their knowledge of setting up Mix Pre6ii as an audio interface,, please?. When recording audio and monitoring with headphones (HP set to USB1,2, on the mixpre) I have major latency issues.
Monitoring using headphones set to LR stereo I have no latency issues but unable to hear USB1,2 - which monitors the two output channels from my DAW.
Ive looked at CPU and plugins and changed the bufferring - no luck
48/24 session with video on 11.3
Really eagre to use this :
Angela
Angela
Win10
PT12.5
Mixpre6ii
Old 10-05-2021, 12:36 PM
Top Jimmy's Avatar
Default Re: Latency with Mix Pre6 as audio interface
Not familiar with the Mix Pre6, but I see a feature listed as USB Output Delay. What does that do?
Otherwise, reducing the buffer size is the only way to reduce the delay if there is no provided “low latency” path. A buffer of 64 or 128 should do the trick.
James Cadwallader
Old 10-05-2021, 03:30 PM
Not sure if this matters, but PT11 on Windows 10 is an unsupported combination
As said, the Playback Buffer needs to be set low(like 64 or 128) for acceptable latency. Beyond that, look at plugin latency and keep those numbers low while recording. I never had an issue with total plugin latency below 64 samples, but I tried to keep it down to 10-11 samples(11 samples was the Console 1 plugin).
S3 AVB interface LATENCY is a problem.. kriszuki Avid S1, S3, Dock and Control App 41 07-10-2015 11:19 AM
Which Audio interface for an Imac & Low latency question stof77 macOS 5 11-07-2012 05:50 AM
Low Latency - Sound Card/Audio Interface Questions Rodge A Pro Tools M-Powered (Win) 9 02-16-2009 10:29 AM
Latency on USB Midi interface.... RingoFire 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-07-2002 01:58 PM
