  #31
Old 09-10-2021, 12:14 PM
operator operator is offline
Default Re: *******Fix for Apple Security Update bricking displays*******
Hi Eddie, thanks for getting back to me.
I`m using Mac OS 10.14.6 (18G103)
I had previously uninstalled the app and prefs, but I did it again anyway. The problem continues.
FWIW, booting from a different partition on the same computer, EuCon works fine. This is using Mac OS 10.13.4 (17E199) and EuControl 2020.11.1.10, EuCon 4.7.4.10.
I tried uninstalling and installing EuControl 2020.11.1.10 on the Mac OS 10.14.6 system, but the problem continues.
I also tried removing the Euphonix folder from Library/Application support as I thought it might be the soft key files that were causing the hang, but the problem continues.
Is there any other location, that stores information that is not removed with the uninstall options, that EuCon might try to access when adding the Artist Control?
The hang report shows: Boot args: -no_compat_check. I don`t know if this information is useful?
  #32
Old 09-10-2021, 12:41 PM
EddieJones's Avatar
Is EuControl and MCClient allowed in the Mac security settings?
  #33
Old 09-10-2021, 02:18 PM
Yes, in Accessibility. It is just MC Control that causes the hang on entering EuCon Settings. With just the Artist Mix there is no hang.
  #34
Old 09-10-2021, 02:23 PM
EddieJones's Avatar
Can you make it hang and then select collect support files and post them or a link to them ?
  #35
Old 09-10-2021, 02:32 PM
Sure: https://www.dropbox.com/s/fmcyk4xfi7...g.txt.zip?dl=0
  #36
Old 09-10-2021, 02:37 PM
EddieJones's Avatar
Sorry, right click on EuControl and in its popup menu click Collect Log Files.
  #37
Old 09-10-2021, 02:50 PM
Sorry : https://www.dropbox.com/s/7r4w5x46ow...84638.zip?dl=0
BTW, I had to force quit EuCon/re-open in order to collect the collect Support files
  #38
Old 09-10-2021, 03:04 PM
EddieJones's Avatar
Does it do this whether Digital Performer is running or not ?
  #39
Old 09-10-2021, 03:12 PM
Nothing running, just Finder, EuCon and Apogee Maestro 2. I just tried without Apogee Maestro 2 , but it still hangs.
  #40
Old 09-10-2021, 03:14 PM
EddieJones's Avatar
How many monitors do you have? If more than one could you try to remove one and test?
*******Fix for Apple Security Update bricking displays******* EddieJones Avid S1, S3, Dock and Control App 61 09-06-2021 11:52 PM
Do not load latest Security Update from Apple Park Seward macOS 5 03-12-2015 06:22 AM
apple security update 2009-002? nst7 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-14-2009 11:45 AM
OK To Do Apple Security Updates? hitshack Pro Tools TDM Systems (Mac) 3 11-30-2006 07:29 AM
Apple's security update is out, should i update? Arvid Gunardi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-25-2003 09:00 AM
