Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools HDX & HD Native Systems (Win)
Old 05-25-2021, 11:25 AM
oldlouisvillerecords oldlouisvillerecords is offline
Default Word Clock Configuration Pro Tools HD
Hello,
I am working on syncing together a pro tools hd tdm rig with loop sync and/or word clock. I have two digidesign 192s 8x16x8, then two 8-channel yamaha preamps connected via aes/ebu, one to each digidesign 192. I am not sure based on reading the manual and the digidesign paper article on jitter on how to best sync these units together via loop sync and/or word clock. In any case, I want to use one of the digidesign 192s as the master clock. I have attached two images below on how I am conceptualizing this.
Thanks for your input.
Old 05-25-2021, 11:29 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Word Clock Configuration Pro Tools HD
DigiDesign interfaces connected via Loop Sync, other boxes via external clock.
Janne
Old 05-25-2021, 01:00 PM
albee1952 albee1952 is online now
What Janne said The OP says he posted 2 images, but they are not showing. The pair of 192's is simple; Loop Sync out to Loop Sync in to create a loop of the 2 units. As for the Yamaha devices, there are probably a few ways, but WC out of the master 192 to either, and jump(daisy-chain) to the second would be the easiest(and make sure both Yamaha units are set to External clock. They may have an LED to show they are receiving clock). If you don't have things clocked correctly, it should be obvious by 1 of 2 things; either all the Yamaha inputs will make clicks and pops when you try to record them, OR, they will simply not pass audio at all
BTW, if these Yamaha units are a few years old, you may want to trade them out for other units as Yamaha were not known for stellar mic preamps in their digital stuff before the CL series
Old 05-28-2021, 11:58 AM
Sugarnutz Sugarnutz is offline
Also make sure you terminate the wordclock on the last Yamaha in the chain. Some devices have a switch for built in termination, if so only turn it on for the last item in the chain.
Gigabyte z390 Designare
I9 990K 4.7 GHz
64 Gb of DDR4 3200
Gigabyte RX580 8 Gb
Win 10 Pro
15" Mid-2015 MBP 2.2 GHz i7 16 Gb RAM
512 Gb Flash Drive - OS X 10.14.6
Old 05-28-2021, 08:47 PM
JFreak's Avatar
Not needed if the cables are short, but best practice anyway. Not terminating drops signal level 3dB but has absolutely zero effect on 1-2 meter cable runs.
Janne
Pro Tools with Apollo 8 Duo word clock question Isadore Pro Tools 12 6 10-10-2017 12:14 PM
Pro Tools 10HD won´t sync to word clock [SOLVED] Simon Johansson Pro Tools HDX & HD Native Systems (Mac) 2 01-31-2016 12:49 AM
best word clock configuration pie55 Pro Tools TDM Systems (Mac) 4 06-30-2013 10:40 AM
DM2000 and Pro Tools Interfaces Word Clock Problem joepopp Pro Tools TDM Systems (Mac) 52 04-01-2008 10:13 PM
Syncing 2 Pro tools systems via Word Clock EDurney 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 05-17-2007 11:57 AM
