Old 02-04-2009, 03:16 PM
calle.vs calle.vs is offline
Default Clip gain???
I am doing post production for swedish television. Very often I get production audio that's been recorded at very low levels. I'm inserting the gain plug-in in Pro tools that will let me automate gain up to 12 db. I really don't like this way of working. In a typical session I will spend a lot of time changing the automation view to gain and drawing an envelope with the mouse. I used to gain the clip in Audiosuite but I found that even more tedious.
Could anyone give me some advice on clip gain in Pro tools. I have seen how apps like Nuendo or Vegas have very simple and fast solutions to this problem.
I tip would be most appreciated.
Thank you!
Calle
Also, does anyone know a shortcut for "solo track"? It drives me crazy.
Old 02-04-2009, 03:28 PM
Dallas Taylor Dallas Taylor is offline
Default Re: Clip gain???
I usually insert an L1 on all of my Dialog Tracks & automate the Threshold. You can do this with any compressor [0:0 ratio...] It'll usually give you 30+ db of gain.
DALLAS TAYLOR CAS/MPSE
/// Sound Designer/Mixer @ Defacto \\\ Twitter Facebook
Old 02-04-2009, 03:45 PM
Reckless Erik Reckless Erik is offline
In PT 8 pressing "shift S" (mac) will put the selected track into solo. Not sure of command for pc users. PT 7.x.x does not have this feature.
On the subject of clip gain you might find some help in this post http://duc.digidesign.com/showthread.php?t=195904
Nick
[email protected]
Newcomer Audio Post
MacBookPro 2.3GHz i7 16GB RAM OSX 10.15.7, PT Ultimate 2023.12 HDn, MTRX Studio, 2x Avid S1, PT Dock...
Mac M1 Studio Ultra 64GB RAM OSX 13.6, PT Ultimate 2023.12 HDn, MTRX Studio, 2x Avid S1, PT Dock...
Old 02-08-2009, 01:42 PM
Ok. It seems like clip gain is something I just have to wait for.
Thanks for replying.
/Calle
Old 02-08-2009, 03:57 PM
petecollins petecollins is offline
Thank you!
Calle
I also had these problems with low level production audio and think 'only' 12dbs of headroom is one of PT's weaknesses. Now I run the dialogues through a subgroup to give my self another 12dbs and use both faders to achieve a better level without clipping. It is far quicker than fiddling around with gain automation or audiosuite, but I too would be interested if someone else has a better method.
Pete
Old 02-08-2009, 05:55 PM
citysoundman citysoundman is offline
There is no easy way to deal with low level production sound. If only audiosuite had a handles setting! As mentioned, I automate the trim plug-in, L1 threshold, and extra auxes when need be. Although I try to keep the limiter threshold untouched, and set trim (or two trims, or use the gain setting on an inserted EQ) to keep things at nominal level.
Do you know the control-command-left/right arrow to quickly change plug-in automation views? It's a great time saver.
Bob Kirschner
NYC-based Audio Post Mixer/Sound Designer
bobkirschner.com
Old 02-08-2009, 06:25 PM
lego lego is offline
No such thing I use Sonalksis Free-G + automation for this purpose.
Shift-S in PT8, mousing-and-clicking before PT8
"The Mackey Big Knob is, you press little button and they can hear through the headphones, you can say whatever you wanted to them without you having to yell." by Tad Donley
Old 02-08-2009, 06:34 PM
While in Shuttle Transport mode (preferences) press the 6 key on extended keyboard.
Bob Kirschner
bobkirschner.com
Old 02-09-2009, 02:47 AM
JWalkerPostAudio JWalkerPostAudio is offline
Or Cntrl+5 (Mac) Start+5 (PC) if you are in LE where shuttle transport mode isn't an option.
Justin Walker
Old 02-12-2009, 11:19 AM
Thank you all!
/Calle
HTML code is On
Adjusting Clip Gain On More Than One Clip Blank Frank macOS 17 05-15-2015 06:34 PM
AudioSuite Gain/Normalize also on Clip Gain A-n-d-i macOS 0 03-13-2014 12:46 PM
Export Clip With Clip Gain BobbyDazzler Pro Tools 10 0 03-03-2013 03:06 PM
Clip gain on clip groups: bug or feature? idris Post - Surround - Video 6 01-02-2013 10:48 PM
How to use X-Key on clip gain? Frank Kruse Post - Surround - Video 6 11-01-2011 11:14 AM
