Old 09-14-2006, 09:38 AM
omons2273 omons2273 is offline
Default +6 or +12db fader gain
Hi people, Writing to see on some opinions about the extra 6db of gain on our protools tracks. Is it a path for problems of making too hot of a mix and cause problems for the Mastering Engineer. I personally stay away from it for that reason, But would like to hear some other opinions. Thanks Oscar
Old 09-14-2006, 10:16 AM
JSR JSR is offline
Default Re: +6 or +12db fader gain
You have the right idea. In my opinion, when mixing music, if you need to push a track greater then +6dB, there is a problem somewhere else in the mix....usually something needs to be lowered or eq'd differently in order to make the sound your focusing on cut through. Making things louder only leads to problems. This takes into account the tracks you're mixing have a decent level.
I find the +12dB feature is really hand in post mixing...namely with dialog. Usually field dialog comes in recorded at extremely low levels and I had to usually Audio Sweet gain, or use the +6db on the fader and also the gain on the Trim plugin before we had +12db. The +12db makes things a bit quicker in situations like this.
Old 07-12-2021, 09:10 PM
noobstudioguy noobstudioguy is offline
Why would this even be an option?
Old 07-13-2021, 09:38 AM
Consider that you dredged up a thread from 2006! Its not an option I am aware of since PT7 or 8
Old 07-13-2021, 10:59 PM
When I "save copy in", there is an option for +6 or +12
Old 07-13-2021, 11:36 PM
Sardi Sardi is offline
That is for backwards compatibility.
Wouldn’t be very good if you raised the fader higher than 6dB and then tried to open the session in an older version of PT that doesn’t have that feature.
Old 07-14-2021, 01:37 AM
Makes sense I guess..so in other words. Don't even worry about +6 or +12, it's not used anymore unless going back to older versions of Pro Tools?
Old 07-14-2021, 04:46 AM
I don’t recall when the change was made, but it was a long time ago. Like… maybe v7…
The likelihood of sharing a session with anyone on a system that old would be VERY slim.
Max Automating gain from +24dB to +12dB WhiteRhino macOS 0 01-14-2013 11:47 AM
10.3 and 10.3.1 Small Volume Fader AND Clip Gain Fader Problem Ale macOS 1 10-11-2012 10:07 AM
How to set fader to 6db not 12db Greene Pro Tools TDM Systems (Mac) 1 04-21-2008 12:52 PM
+12dB fader gain and exported OMF files. matt connolly Post - Surround - Video 1 04-07-2005 10:50 PM
Why does Pt master fader sound best @ -12dB? NATEMYST Pro Tools TDM Systems (Mac) 6 06-04-2002 12:47 AM
