Old 06-14-2006, 10:39 PM
Glenn75 Glenn75 is offline
Default Recording Virtual instrument thru internal Bus?
I am recording Battery 2 through an internal bus on to audio tracks and the audio is not lining up with the midi information. The strange this is the audio information appears to be in front of the midi info rather than behind??? Is this normal? Aren't recordings of virtual instruments through internal bus supposed to be sample accurate? And is there a setting/preference that I need to double check to insure accuracy?
Old 06-14-2006, 11:07 PM
Default Re: Recording Virtual instrument thru internal Bus?
Wow, I just read the thread about the 20 millisecond early problem. My Battery 2 recordings are ahead of the Midi info by 22 milliseconds. Is this occuring with all recordings? Is this only occuring with virtual instruments? I have 4 sessions to mix tomorrow morning so I've been tracking all the virtual instruments down to wavs. This is unbelievable. I need to know exactly what is causing this.
I'm running 7.1cs7
Mac OS 10.4.6
here's the thread I found about the problem:
http://duc.digidesign.com/showflat.p...=&fpart=2&vc=1
Old 06-15-2006, 12:19 AM
crizdee's Avatar
crizdee crizdee is offline
Try turning ADC off when you bounce the audio, or try turning it off if it already on!
Unless it is drum/percussion parts the delay will be so small it won't be noticeable to the ear! if it is drum parts, then realighn to the grid or the original source.
Chris
Producer, Engineer,
www.ukmastering.com
Old 06-15-2006, 09:45 AM
So that's it? I'm suprised that this isn't of bigger concern to you guys.
Multiple Virtual Instrument Playback while recording eklektos Virtual Instruments 4 11-08-2008 04:13 PM
Lag when using virtual instrument... onebigtrip 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 04-22-2008 10:47 AM
Virtual Instrument Recording Problems AdrianLesher Virtual Instruments 0 11-18-2006 11:44 PM
Recording Audio From virtual instrument /Battery 2 Rome Production General Discussion 1 04-28-2005 07:22 PM
Recording Virtual Instrument Audio cc1 Tips & Tricks 2 07-21-2004 08:48 PM
